    M122 Module Reset Reason
    304
    • CarlBossonundefined
      CarlBosson
      Also in the M122 Network diagnostics check the WiFi Module Reset Reason. It should be "turned on by main processor". If it is anything else (e.g. "exception"), report the problem on the forum.
      === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-917DA-G4MSD-6J1FA-3SJ6N-T8T39<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 25524<LF>Dynamic ram: 98472 of which 0 recycled<LF>Exception stack ram used: 320<LF>Never used ram: 6756<LF>Tasks: NETWORK(ready,1240) HEAT(blocked,1208) MAIN(running,3844) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:25:17 ago, cause: power up<LF>Last software reset at 2019-09-05 13:09, reason: User, spinning module GCodes, available RAM 6688 bytes (slot 3)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 32.6, current 40.3, max 40.5<LF>Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, <Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
      There is no box!
      A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
      • A Former User?
        A Former User @CarlBosson
        @CarlBosson said in M122 Module Reset Reason:
        ref https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
        • T3P3Tonyundefined
          T3P3Tony administrators @CarlBosson
          Please set YAT to <LF> endings:
          Terminal->Settings->Text Settings-> EOL sequence <LF>
          www.duet3d.com
            CarlBosson
            T3P3 Thanks, This is done. Now, What did I do ☺ ?
            There is no box!
            • A Former User?
              A Former User
              Run M122 again and post the complete output. (if you could put ``` on the line over and under when you post it'll be easier to read)
                CarlBosson
                Bearer,
                Here it is.
                '''=== Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-917DA-G4MSD-6J1FA-3SJ6N-T8T39<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 25524<LF>Dynamic ram: 98472 of which 0 recycled<LF>Exception stack ram used: 312<LF>Never used ram: 6764<LF>Tasks: NETWORK(ready,1412) HEAT(blocked,1208) MAIN(running,3844) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:06:34 ago, cause: power up<LF>Last software reset at 2019-09-05 13:09, reason: User, spinning module GCodes, available RAM 6688 bytes (slot 3)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 31.6, current 39.5, max 39.6<LF>Supply voltage: min 24.4, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, <Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>'''
                There is no box!
                • A Former User?
                  A Former User
                  You need to do as Tony suggested before running M122 (maybe you have to do it again if you close the terminal software, not famliar with it myself) as the terminal is still truncating the output.
                  T3P3Tony said in M122 Module Reset Reason:
                  then run M122 again and post the output, should be several lines and not one super long one.
                    CarlBosson
                    Bearer,
                    Lets try this again. I did not know I had to do that step each time, sorry.
                    '''=== RTOS ===
                    Static ram: 25524
                    Dynamic ram: 98516 of which 0 recycled
                    Exception stack ram used: 440
                    Never used ram: 6592
                    Tasks: NETWORK(ready,648) HEAT(blocked,1176) MAIN(running,3788) IDLE(ready,200)
                    Owned mutexes:
                    Last reset 00:21:25 ago, cause: power up
                    Error status: 0
                    Free file entries: 9
                    MCU temperature: min 39.1, current 42.7, max 42.8
                    Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: ok, SG min/max 0/364
                    Driver 1: ok, SG min/max 37/234
                    Driver 3: ok, SG min/max 0/1023
                    Date/time: 2019-09-12 08:42:51
                    Slowest loop: 103.27ms; fastest: 0.08ms
                    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 153, MinFreeDm: 151, MaxWait: 596942ms, Underruns: 0, 0
                    Scheduled moves: 3831, completed moves: 3801
                    Bed compensation in use: none
                    Heater 0 is on, I-accum = 0.0
                    Heater 1 is on, I-accum = 0.2
                    Segments left: 1
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is doing "G1 X177.900 Y260.515 E0.9780" in state(s) 0
                    serial is ready with "M122" in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 165.15ms; fastest: 0.08ms
                    HTTP sessions: 1 of 8
                    • WiFi -
                      Network state is running
                      WiFi firmware version 1.21
                      WiFi MAC address cc:50:e3:0d:29:ce
                      WiFi Vcc 3.40, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 17184
                      WiFi IP address 192.168.1.21
                      WiFi signal strength -68dBm, reconnections 0, sleep mode modem
                      ok'''
                    There is no box!
                    • T3P3Tonyundefined
                      WiFi -
                      ok'''
                      so that looks ok... not the best signal strength. whats not working?
                      www.duet3d.com
                        CarlBosson
                        At this point everything is running as it should.
                        There is no box!
