Guidance Needed Please
Hi All
SO after finally getting the wifi board set up and configured things dont seem to work as expected.
I have a CR10, installed the Duet wifi board. connected all the connectors accordingly. So here is where i am stuck.
I used the configuration wizard to get my initial configuration done. I can now get each individual part working, bed heats nicely and quickly. Hotend, stepper motors. That all said, i cant seem to get them all working together.
Any suggestions of where i should start looking? Does anyone have a working config for the CR10?
Upgrades: E3D Titan DD and motor with V6 hotend.
Thanks
Shaun -
Though aimed at the Duet Maestro, this series of How-to guides for Ender 3 Pro (pretty similar to the CR10) here walk you through the process, and most information is compatible with the Duet Wifi:
https://duet3d.dozuki.com/c/Duet_2_Maestro#Section_How-to
If you could be a bit more specific about how you can't "get them all working together", that would help!Ian
@Shaun so if you have got every part working individually then you probably have done the majority of the steps in this guide:
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
but check.Then I would move onto the next guide:
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40I know these are for a slightly different printer and controller but the theory remains valid - just tweak the numbers to fit with the CR10 size etc.
(the second guide in that series has some steps about how to get the numbers form the old configuration)
@droftarts was too quick!
Thanks, ill try it tonight.
