    Duet 2 Wifi- wifi connect problems
    574
    • TPJensenundefined
      TPJensen
      Hi
      Now my duet runs very good there is only one problem.
      If I turn on the printer and not connect fast in my browser it dont connect.
      If I then are connected and the PC goes to sleep it cant connect again
      My router is setup to the printer gets same IP everytime
      What can I do to correct that ?
      Running
      2.04RC1 firmware
      • T3P3Tonyundefined
        T3P3Tony administrators @TPJensen
        @TPJensen that is very weird. are you able to connect to USB as well as WIFI and the use the USB to check what is happening to the WIFI network (M122 gives status). Another idea is to check that its not your PC/router/duet incompatibility by trying to ping the duet and see what happens if you don't connect - is the Duet still on the network?
        to do that (under windows) use the command
        ping 192.168.1.14
        from powershell or the command line, replacing the IP address with the address of your duet.
        www.duet3d.com
        TPJensenundefined 1 Reply Last reply Reply Quote 0
        • TPJensenundefined
          TPJensen @T3P3Tony
          @T3P3Tony said in Duet 2 Wifi- wifi connect problems:
          ping 192.168.1.14
          Yes it is wierd.... I can concect to USB
          Is shows that the duet is on the network and if I ping the ip also fine.
          if I keep trying to connect if browser then it sometimes show up again.
          PanelDue also tell it is connected to wifi and IP 192.168.1.66
          I also used Ipad , Iphone, laptop and my (windows) Computer.. all cant connect but if one cant the others ones cant eighter.
          • T3P3Tonyundefined
            @TPJensen can you check you are on the latest version of DWC? I assume you are if using 2.0.4RC1?
            www.duet3d.com
            TPJensenundefined 2 Replies Last reply Reply Quote 0
            • TPJensenundefined
              TPJensen @T3P3Tony
              Firmware Version: 2.04RC1 (2019-07-14b1)
              WiFi Server Version: 1.23
              Web Interface Version: 1.22.6
              Web Interface by Christian Hammacher
              Licensed under the terms of the GPL v3
              • TPJensenundefined
                TPJensen @T3P3Tony
                • T3P3Tonyundefined
                  @TPJensen what does M122 report when you cant connect to the printer - and what error do you get in the browser?
                  www.duet3d.com
                    What browser are you using?
                    Do you have another browser installed you can try to see if it behaves the same?
                    As a shot in the dark can you try clearing your browser cache?
                    Can you try increasing the number of AJAX retries? It's the setting in the middle of the screen in your last screenshot. It's 1 now, try 3 or 4.
                    • TPJensenundefined
                      TPJensen @Phaedrux
                      @Phaedrux said in Duet 2 Wifi- wifi connect problems:
                      Can you try increasing the number of AJAZ retries? It's the setting in the middle of the screen in your last screenshot. It's 1 now, try 3 or 4.
                      I use Chome in windows pc. also I did try edge
                      Ipad safari
                      Phone Safari
                      Laptop firefox
                      All the same result.... I have tried clear browser cache with no luck on the duet.
                      I will try to increase AJAX to 3 and if that helps
