CR-10S5 Firmware
@droftarts Thank you, indeed I'm in the USA. I will let you know the resolution of this.
For the benefit of others reading this thread, we make the following recommendation in https://duet3d.dozuki.com/Wiki/Power_Wiring :
Important! Re-tighten the terminal block screws after doing the first few prints, and check that they are still tight occasionally after that. The heat generated by the high current carried by the power wires can cause them to creep and make the connection less tight, especially if you used stranded core wire and no ferrules.
Unfortunately we have seen that not everyone follows this advice, and not everyone has the right tools to crimp the ferrules. That's why we switched to barrier strips on Duet Maestro and Duet 3, which we hope will be reliable even when not re-tightened.
@dc42 Thank you, for some reason the link that you have attached is not working. But I understand the quote. Are the Duet 3s out yet?
I'm sorry, the forum software appended the colon to the URL. I've edited it now.
Duet 3 is out, but it's more expensive than Duet 2 and overkill for most 3D printers.
do you really need the link when the relevant section is quoted inline in the post?
nor does it take a whole of imagination to see that the forum have included the : in the posted url, remove it and it works just fine.
https://duet3d.dozuki.com/Wiki/Power_Wiring -
@bearer I understood what he meant. New comers might not, that's why I mentioned it. Well you all have a wonderful rest of your day.
