    CR-10S5 Firmware
    Firmware installation
    15
    145
    8.2k
    • Gost101undefined
      Gost101 @Veti
      @Veti I dont have any start code.
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @Gost101
        @Gost101
        post the start of a g code where the print has been slow
        • Gost101undefined
          Gost101
          ;FLAVOR:RepRap
          ;TIME:13024
          ;Filament used: 5.97829m
          ;Layer height: 0.12
          ;MINX:209.345
          ;MINY:227.132
          ;MINZ:0.144
          ;MAXX:279.794
          ;MAXY:272.866
          ;MAXZ:48.914
          ;Generated with Cura_SteamEngine 4.4.1
          T0
          M190 S50
          M104 S210
          M109 S210
          M82 ;absolute extrusion mode
          M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
          M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
          M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
          M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
          M220 S100 ;Reset Feedrate
          M221 S100 ;Reset Flowrate
          G28 ;Home
          G92 E0 ;Reset Extruder
          G1 Z2.0 F3000 ;Move Z Axis up
          G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
          G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
          G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
          G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
          M83 ;relative extrusion mode
          ;LAYER_COUNT:400
          ;LAYER:-6
          • Gost101undefined
            Gost101
            Regardless of infill, wall thickness and layer height it prints extremely slow.
            • Vetiundefined
              Veti
              @Gost101 said in CR-10S5 Firmware:
              those lines must be in the start g code of your slicer. thats why the print is slow.
              remove them
              • Gost101undefined
                Gost101
                @Veti said in CR-10S5 Firmware:It seems to be moving faster but how do I compensate for the extrusion factor? Lines are becoming to small and separating multiple times in one movement.
                • Vetiundefined
                  Veti @Gost101
                  is your thermistor set up correctly? are your e steps set up correctly?
                  • Gost101undefined
                    Gost101
                    @Veti Yes they are, just got back to my benchy test print ive been gone for almost 6 hours and cura said that it was a 3 hour print. Turns out the printer is not fast still. What should do?
                    • Gost101undefined
                      Gost101
                      • Vetiundefined
                        Veti
                        did you restart the printer after you made those changes? anytime you are printing an old file you will revert the settings and need to reboot.
                        Gost101undefined 1 Reply Last reply Reply Quote 0
                        • PaulHewundefined
                          PaulHew
                          FYI I think the start code Veti is referring to is in your slicer.
                          If it is Cura.
                          Settings - Printers - manage printers
                          Select your printer and click 'Machine Settings'
                          On that page at the bottom there is a window with Start G-Code
                          Remove the lines you have been asked to remove.
                          HTH
                          Paul.
                          RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                          Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                            Phaedrux Moderator @Gost101
                            Your screen shot shows the top speed as 8.4mm/s which is basically 500mm/min. So I think you still haven't removed the limiting start gcode from cura. Follow the directions that @PaulHew has given.
                            Once that change is made it will only apply to newly sliced files. All your previously sliced files will have the slow limits set.
                            • Gost101undefined
                              Gost101 @Veti
                              @Veti I did reboot it. I did find that in cura and deleted it. lol
                              • Gost101undefined
                                Gost101
                                @Phaedrux @PaulHew @Veti Great confusion this printer has caused me, yet more to learn I must. Sorry I have been watching to much star wars. lol.
                                • Gost101undefined
                                  Gost101
                                  START
                                  G28 ;Home
                                  STOP
                                  G91 ;Relative positioning
                                  G1 E-2 F2700 ;Retract a bit
                                  G1 E-2 Z0.2 F2400 ;Retract and raise Z
                                  G1 X5 Y5 F3000 ;Wipe out
                                  G1 Z10 ;Raise Z more
                                  G90 ;Absolute positionning
                                  G1 X0 Y{machine_depth} ;Present print
                                  M106 S0 ;Turn-off fan
                                  M104 S0 ;Turn-off hotend
                                  M140 S0 ;Turn-off bed
                                  M84 X Y E ;Disable all steppers but Z
                                    And what speeds are set in cura for printing moves?
                                    • Gost101undefined
                                      Gost101
                                      @Phaedrux For this profile it is:PrintSpeedCapture.PNG
                                      • Gost101undefined
                                        Gost101
                                        @Phaedrux Regardless of any adjustments to this, it still takes a long time to print. Even after the changes made.
                                          Can you post a gcode file somewhere for us to see? And perhaps your current config.g file as it is right now?
                                          • Gost101undefined
                                            Gost101
                                            Heres the benchy file: Benchy GCode
                                            ;config.g
                                            ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 (6:00PM for Civs).
                                            ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr-10s5-firmware/37
                                            ; Contact gost1017@gmail.com for more help.
                                            G90                                        ; send absolute coordinates...
                                            M83                                        ; ...but relative extruder moves
                                            M550 P"A.C.E."                             ; set printer name
                                            M669 K0                                    ; select Cartesian mode
                                            M551 P"SpaceForceHu2020!!"                 ; set password
                                            M552 S1                                    ; enable network
                                            M586 P0 S1                                 ; enable HTTP
                                            M586 P1 S0                                 ; disable FTP
                                            M586 P2 S0                                 ; disable Telnet
                                            M569 P0 S1                                 ; X physical drive 0 goes forwards
                                            M569 P1 S1                                 ; Y physical drive 1 goes forwards
                                            M569 P2 S0                                 ; Z physical drive 2 goes backwards
                                            M569 P3 S0                                 ; E physical drive 3 goes forwards
                                            M584 X0 Y1 Z2 E3                           ; set drive mapping
                                            M350 X16 Y16 Z16 E16 I1                    ; configure microstepping with interpolation
                                            M92 X80.00 Y80.00 Z400.00 E408.30          ; set steps per mm
                                            M566 X500.00 Y500.00 Z30.00 E1500.00      ; set maximum instantaneous speed changes (mm/min)
                                            M203 X10800.00 Y9000.00 Z300.00 E3000.00   ; set maximum speeds (mm/min)
                                            M201 X1000.00 Y1000.00 Z500.00 E3000.00      ; set accelerations (mm/s^2)
                                            M906 X950 Y950 Z850 E900 I30              ; set motor currents (mA) and motor idle factor in per cent
                                            M84 S30                                    ; Set idle timeout
                                            M208 X0:500 Y0:500 Z0:500                  ; set axis maxima
                                            M574 X1 Y1 Z1 S1                           ; set active high endstops
                                            M558 P0 H5 F120 T6000                      ; disable Z probe but set dive height, probe speed and travel speed
                                            M557 X15:215 Y15:195 S20                   ; define mesh grid
                                            M305 P0 T100000 B3950 R4700                ; set thermistor + ADC parameters for the heated bed
                                            M143 H0 S120                               ; set temperature limit for heater 0 to 120C
                                            M305 P1 T100000 B4725 C7.060000e-8 R4700   ; set thermistor + ADC parameters for heater 1
                                            M143 H1 S550                               ; set temperature limit for heater 1 to 550C
                                            M106 P0 S0 I0 F500 H-1                     ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                            M106 P1 S1 I0 F500 H1 T45                  ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                            M563 P0 D0 H1 F0                           ; define tool 0
                                            G10 P0 X0 Y0 Z0                            ; set tool 0 axis offsets
                                            G10 P0 R0 S40                              ; set initial tool 0 active and standby temperatures to 40C
