So, I blew up a WK8 P9 at TR5
As the subject says, I have a Duet WiFi, V1.02, and a wire was ripped from the hot end assembly (fan wire, if I recall correctly) which shorted the board. The board boots up but it's not working correctly anymore. It appears as though a component labeled "WK8 P9" (transistor, I assume) with three leads on it located at TR5 blew up.
Can someone tell me what this is so I can attempt to get a replacement and fix the board?
Thanks.
TR5 is a PMV40UN2 N-Channel MOSFET.
Data sheet here: Nexperia PMV40UN2
It controls the part cooling fan, so that matches with the short circuit.
Awesome. Thank you!
