    Around the fans ...
    • peirofundefined
      peirof
      Help with fans...
      i have:
      Hardware:
      • 2x30mm fans (linked) conected to FAN2, for heatskin
      • 1x40 mm fan connected to FAN1, layer fan
      • 1x40 mm fan connected to FAN0, layer fan
      Software (config.g)
      M106 P0 S1 I0 F500 H-1
      M106 P1 S1 I0 F500 H-1
      M106 P2 S1 I0 F500 H1 T60
      M563 P0 D0 H1	; Define tool 0
      G10 P0 S0 R0		 ; Set tool 0 operating and standby temperatures
      The issue:
      • If i heat nozzle, when reach temperature, two fans linked, powe on
      • But, when i command in DWC, manual, that Nozzle fan go 100%, slicer control of FAN 1, its linked.... the same manner if i command by DWC, that fan1, go 0%, Nozzle fan too goes 0%, are linked too
      • When command for DWC, nozzle fan, in console can read: M106 S0.xx, but when command for DWC, fan1, in console can red: M106 P0 S0.xx, and Fan1, in console can read: M106 P1 S0.xx.
      Maybe the solution its change Heatskin fan to Socket of FAN0???
      Why?
      • peirofundefined
        peirof
        YES...
        With these i have solved....
        I HAVED CHANGE HEATSKIN FAN TO FAN0 SOCKET
