    How to find the bad command in config.g?
    • zapta
      zapta last edited by
      When I upload my config.g, I see the following error message on the PanelDue:
      "Error: Bad command: Configuration file for Duet Wifi"
      Is there an easy way to determine what is the bad command?
      • Veti
        Veti last edited by
        you post the config.g here.
        but there was a problem with the resume line from the configurator. try commenting that line.
          Look for the text: "Configuration file for Duet Wifi" in your config.g. I suspect you're missing a semi-colon to comment out a line.
          You can also send M98 Pconfig.g to re-execute the config.g macro and see any error messages or bad commands thrown to the gcode console.
          zapta 1 Reply Last reply Reply Quote 0
          • zapta
            zapta @Phaedrux last edited by
            @Phaedrux said in How to find the bad command in config.g?:
            Bingo!!!
            I assumed that "Configuration file for Duet Wifi" was a generic duet's message but apparently it was trying to tell me exactly what is the offending code.
            Yes, a missing semicolon. 😉
