    Finding the MAC address
    2.0k
    • heoconnorundefined
      heoconnor
      Looking for the MAC address to register my duet with IT services where I work (to connect it to the ethernet). Is there a command I can use in YAT to find this?
      • A Former User?
        A Former User
        Should be part of the output of M122but do take care to set the line ending to LF if on windows.
          heoconnor
          M122 just comes back with: Emergency stop! Reset the controller to continue.ok 😕
          • PaulHewundefined
            PaulHew
            Your IT dept could tell you the MAC address if they wanted.
            You could plug it into the network tell them the IP address and they can find the MAC that way.
            Or ask them for an IP address, set it, they can scan and cross reference the IP to the MAC.
            RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
            Voron 2.4 disassembled..... Waiting for the RailCore Mini....
            • DocTruckerundefined
              DocTrucker
              MAC address is usually set in config.g.
                DocTrucker
                Run M540
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M540_Set_MAC_address
                Edit: M540 on its own should return MAC address. Read the link to see how to set MAC address.
                • A Former User?
                  A Former User @DocTrucker
                  @DocTrucker said in Finding the MAC address:
                  Run M540
                  aye, that works! didn't see it was specified ethernet, and not sure if it works for the wifi?
                  DocTruckerundefined 1 Reply Last reply Reply Quote 0
                    DocTrucker @A Former User
                    @bearer Oh yeah, didn't think about the wifi half of the equation!
                      DocTrucker
                      "Note on the Duet 2 Wifi the MAC address is unique and set on the Wifi Module so this command has no effect. The default MAC address on a Duet 2 Ethernet is generated from the unique processor ID so there is normally no need to change it."
                      So trying to set it with M540 won't work. Whether or not it reports the correct address would have to be checked. Can you access your router and confirm from there?
                      • A Former User?
                        OP seems to be on Ethernet so thats okay, I was just curious about the wifi for future reference; ultimately a moot point as M122 doesn't seem include mac address for Ethernet (on the Maestro at least)
                          Phaedrux Moderator @heoconnor
                          @heoconnor said in Finding the MAC address:
                          I think you might have sent M112
                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M112_Emergency_Stop
                          • Danalundefined
                            Danal
                            Via a Windows machine command prompt:
                            C:\Users\Danal>ping 192.168.7.100
                            Pinging 192.168.7.100 with 32 bytes of data:
                            Reply from 192.168.7.100: bytes=32 time=3ms TTL=255
                            Reply from 192.168.7.100: bytes=32 time=36ms TTL=255
                            Reply from 192.168.7.100: bytes=32 time=168ms TTL=255
                            Reply from 192.168.7.100: bytes=32 time=64ms TTL=255
                            Ping statistics for 192.168.7.100:
                                Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
                            Approximate round trip times in milli-seconds:
                                Minimum = 3ms, Maximum = 168ms, Average = 67ms
                            C:\Users\Danal>arp -a 192.168.7.100
                            Interface: 192.168.7.210 --- 0x13
                              Internet Address      Physical Address      Type
                              192.168.7.100         2c-3a-e8-0b-2f-27     dynamic
                              DocTrucker @Danal
                              @Danal neat, copies directly to linux to:
                              doctrucker@BURPSPC:~$ arp -a 192.168.82.1
                              fritz.box (192.168.82.1) at e0:28:6d:bb:41:cc [ether] on enp8s0code_text
                                heoconnor
                                Got it using the M540 - Thanks everyone!!
