    12864 Display on a working Maestro
    My Duet controlled machine
    • PaulHewundefined
      PaulHew
      I have been throught everything and am a bit lost.
      I decided to connect the original display to my Maestro after moving the PanelDue to my RailCore.
      I have the M918 P1 E4 F2000000 command in and it displays 'Duet Maestro Self-Test'
      Where do I get the files for the menus and how do I upload them, please.
      I do not want to re do my config in the RRF, but I did create a base ender3 config and there is a folder called 'Menu' with a file called main.
      Is it a case of take SD card out and drop the Menu folder onto the SD card?
      Thanks in advance
      Paul.
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      • A Former User?
        A Former User
        maybe links in this post helps?
        https://forum.duet3d.com/topic/10460/geeetech-12864-lcd-w-duet-2-maestro
        • PaulHewundefined
          PaulHew
          Thanks @bearer , greatly appreciated.
          I will give it a go.
          Paul
          • PaulHewundefined
            PaulHew
            Brilliant, that was quick and easy!
            Had to revert back to the original DWC but all works.
            thanks again @bearer
