    PS_ON to DuetWIFI
    • georgepaul
      georgepaul last edited by
      i have the Duet Wifi and a relay block(not with the circuit just https://components101.com/5v-relay-pinout-working-datasheet) do i need to connect a diode and stuff or can i just do without it.
      One end of coil connected to PS_ON and the other connected to ground or 5V IN??
      i will add the M81 command in the slicer end code.
      is there anything i have to do in the config.g???
      • pipersw
        pipersw last edited by
        you need to connect a diode in parallel with the coil, cathode on 5V and anode on PS_ON pin.
        Add M80 in start gcode of your slicer, and M81 S1 in the end gcode.
        georgepaul 1 Reply Last reply Reply Quote 1
        • georgepaul
          And the jumper should be in internal 5V En or should i connect a USB and set the jumper to external 5V enable.??
          EasyTarget 1 Reply Last reply Reply Quote 0
          • georgepaul
            georgepaul @pipersw last edited by
            @pipersw i have connected a IN4007 diode in parallel to the coil
            • EasyTarget
              EasyTarget @georgepaul last edited by EasyTarget
              @georgepaul said in PS_ON to DuetWIFI:
              I leave mine on internal, if you use USB for the 5v supply (like me) then the Duet falls back on this without problems once the PSU/onboard supply disappears.
              Whats the Duet Doing? Printeye tells you at a glance.
              Currently more into CNC's etc, and home made controllers, but it's Duet for the things that matter.
              • georgepaul
                yes i too got it working on separate USB.. works well... i was wondering why i am not getting 5V at the pin next to the PS-ON pin.
                pipersw 1 Reply Last reply Reply Quote 0
                • pipersw
                  pipersw @georgepaul last edited by pipersw
                  Because it's the 5v input for the board. You have to connect this pin to the 5v power supply and put the jumper to 5v ext in order to use this pin.
