    Simplify3D question
    25
    6.0k
    • deckingmanundefined
      deckingman
      @DjDemonD:
      Okay so im running prusa slic3r 1.34 and cannot see the "small perimeters" options anywhere. There is an "external perimeters", and "perimeters"….. Where should I be looking?
      That sounds like it's either been moved or dropped. I'm still on Prusa edition 1.31.5 and "Small Perimeters" are between "Perimeters" and "External Perimeters" (same as Slic3R 1.2.9).
      • Nuffeundefined
        Nuffe
        @deckingman:
        @DjDemonD:
        I am on 1.34.0 and I have small perimeters speed setting.
        • Dougal1957undefined
          Dougal1957
          Where is it then I can't find it in 1.34.1
          • Nuffeundefined
            Nuffe
            I just installed 1.34.1. It is there too. "Print Settings->Speed"
            • Neotkoundefined
              Neotko
              Using this scripting process you could make outside lines to have special accel/jerk and keep the non visible prts at max speed
              https://ultimaker.com/en/community/40307-simplify3d-fans-only-on-perimeters?page=last
              Juat read the scripting and add the gcodes for each part
