    Curious about a missing capacitor
    Order discussion
    679
    • AlexMlundefined
      AlexMl
      I received my Duet Wifi 1.04c and realized that there is no capacitor soldered onto C99. All pictures that I found on the web show a capacitor at this spot and I didn't read of any change, so I want to make sure that the circuit is ok before I disassemble my working printer.
      Can anyone please confirm whether this is by intention or should I file an RMA?
      Thanks and best regards,
      Alex
      DocTruckerundefined 1 Reply Last reply Reply Quote 0
      • DocTruckerundefined
        DocTrucker @AlexMl
        @AlexMl appears to be one of the capacitors after U3. U3 is responsible for providing 5VDC from V_IN.
        https://github.com/T3P3/Duet
        Wait for the Duet team to comment on it's presence. I can't see where the notes are for the changes on hardware revisions.
          C99 has been omitted intentionally in the most recent Duet WiFi production.
          themelleundefined DocTruckerundefined 2 Replies Last reply Reply Quote 0
          • AlexMlundefined
            AlexMl
            Thank you very much @DocTrucker and @dc42 ! Looking forward to install the board! 👍
            • themelleundefined
              themelle @dc42
              @dc42 said in Curious about a missing capacitor:
              Is this a self-contained change - so users of older 1.04 boards may also just remove C99? Or is it part of a bigger rework with multiple dependent changes?
                It's a self-contained change. But there is no need to remove it if your Duet is working properly.
                themelleundefined 1 Reply Last reply Reply Quote 0
                • themelleundefined
                  themelle @dc42
                  Thanks a bunch, David!
                    DocTrucker @dc42
                    1.04b pdf? Is there a readable list of changes any where to save us needing to ask about changes or play spot the difference when pdfs are available?
                    • T3P3Tonyundefined
                      T3P3Tony administrators @DocTrucker
                      @DocTrucker I have uploaded the pdfs here:
                      https://github.com/T3P3/Duet/tree/master/Duet2/Duet2v1.04
                      The version history explains the overview of the changes:
                      https://duet3d.dozuki.com/Wiki/Hardware_Overview
                      We don't publish a list of everything component moved/added/changed/set to DNP etc.
                      www.duet3d.com
                        droftarts administrators
                        Particularly as C99 is near the 5V regulator, I expect it's related to this:
                        "Further minor component value change/tweaks to improve 5V regulator and EMI performance."
                        https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_PCB_revision_v1_04a_b_c
                          DocTrucker @T3P3Tony
                          @T3P3Tony thanks, the combination of schematics and readable over view is plently.
                          @droftarts yes, I suspected something along those lines as it was on the output of U3. Tony added the readable comments at the same time as the pdfs:
                          https://duet3d.dozuki.com/Wiki/History/Hardware_Overview?revidA=2007&revidB=2367
