    PanelDue Usb port broke off…
    1.0k
    • Iiraiundefined
      Iirai
      I was updating the firmware on the PanelDue 1.1 when I broke off the usb port while pressing the erase button. Is there a workaround for updating it still or am I SOL?
      Computer Engineering Student
      Duet Wifi Delta 560mm W x 1000mm H; ; Print area 400mm circle by 300-360mm height
        It's possible to take a USB cable, cut the device connector off, and solder the wires on to the PanelDue controller. Or send me a PM and I'll do you a special price on a replacement controller.
        • Iiraiundefined
          Iirai
          Thanks, that was a good idea, I was able to flash the firmware on it. Need to find my glue gun to keep things like that in place….
          • Eddiieundefined
            Eddiie
            mine broke a long time ago.
            • ShadowXundefined
              ShadowX
              You might want to shorten those exposed wires on the green, white and red. You don't want them to short to each other. Just trim and leave enough exposed for the solder joint.
              • Iiraiundefined
                Iirai
                I do need to clean that up, I've gotten sloppy at soldering. 😕
