Need help programming Ender 3 Pro a d bltouch
I’ve ran through reprap configurator several times trying to get auto calibration set up. It starts by homing off the bed and the probe doesn’t deploy. Like it is looking for an endstop and not using the probe. The probe does deploy on start up like a test.
I suggest you post your config.g and homing files so we can see what the web configurator has given you.
The fact it's doing a self test at startup is promising, that would indicate that it's wired correctly at least. The behaviour you describe would indicate that the homing files just need to be modified.
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
@3DEric
do you have deploy probe and retract probe.g because it will call when you use bltouch
and to make home at center of bed you have to modifide home z and home all .g to some thig like this; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v2.0.3 on Tue Sep 10 2019 09:03:06 GMT+0700 (Indochina Time)
G91 ; relative positioning
G1 Z5 F18000 S2 ; lift Z relative to current position
G90 ; absolute positioning
G1 X110 Y110 F18000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F300 ; lift Z relative to current position
;G90 ; absolute positioning; homeall.g
; called to home all axes
G1 S1 X-235 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X5 Y5 F18000 ; go back a few mm
G1 S1 X-235 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 X110 Y110 F18000 ; go to first bed probe point and home Z
;G90 ; absolute positioningand in deploy and retrat probe.g have a look at bltouch control command
Thanks for the reply.
Are these the right files?
Config.g
; Configuration file for Duet Maestro (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.0.5 on Fri Oct 18 2019 18:35:27 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Ender 3 Pro" ; set printer name; Network
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z260 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; set active high endstops; Z-Probe
M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M305 P0 T100000 B4092 R2200 ; set thermistor + ADC parameters for heater 0
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M305 P1 T100000 B4092 R2200 ; set thermistor + ADC parameters for heater 1
M143 H1 S275 ; set temperature limit for heater 1 to 275C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
Homing
; homeall.g
; generated by RepRapFirmware Configuration Tool v2.0.4 on Thu Oct 10 2019 13:52:23 GMT-0400 (Eastern Daylight Time)
G1 S1 X-240 Y-240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X5 Y5 F6000 ; go back a few mm
G1 S1 X-240 Y-240 F240 ; move slowly to X and Y axis endstops once more (second pass)
G1 S1 Z-265 F3000 ; move Z down stopping at the endstop
G92 Z0 ; set Z to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v2.0.4 on Thu Oct 10 2019 13:52:24 GMT-0400 (Eastern Daylight Time)
G1 S1 X-240 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 S1 X-240 F240 ; move slowly to X axis endstop once more (second pass)
G1 Z-5 F6000 S2 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 S1 Y-240 F3000 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 S1 Y-240 F240 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
G1 S1 Z-265 F3000 ; move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
@3DEric said in Need help programming Ender 3 Pro a d bltouch:
G92 Z0 ; set Z to axis minimum (you may want to adjust this)This section of home all and home z need to be replaced with a G1 X and Y move to place the probe at the center of the bed and then a G30 to probe z0.
See example here https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z_using_a_Z_probe
