Reed switch endstops. Anybody else using them?
  • I was going to post this on @bartolomeus 'delta experts' thread but thought it could stand on it's own, I do not see any real prior discussion here/generally about this.
    As I upgraded my Delta I wanted to get rid of the 45cent microswitches it used (although they were working just fine, and now do endstop duties very reliably in my CNC, nothing 'wrong' with them) .
    After some thought and inconclusive research I ended up fitting three of these:
    They are pre-wired encapsulated reed switches, the little neodymium bar magnet next to it triggers at approx 9mm range, reliably and repeatably. Together with the magnets they cost more than I'd paid for the 3 aliexpress hall-effect sensors I didnt fit. You can see how small they are!
    Fitting being the nicest part of this:
    Looking at this I'm reminded I could shave 10mm off those tpu bumpstops/mounts with minimal effort.
    I soldered extensions to the wires, and they run down the front of each 2020 axis rail under a clip-in slot cover. Utterly invisible (which is important to me) and I had no need to mess around with 3 wires and bulky/vulnerable mounts.
    Crucially; the limited research I did suggests that these have excellent repeatability, and my experience bears this out. Sunflower (my Delta) keeps calibration when the PSU is off between prints; and an informal 10 second power outage test(*) picked up the resumed layer almost perfectly despite re-homing. Config/wiring identical to a NO endstop, if doing this again I might try and find NC reedswitches if they exist.
    To put it bluntly: I'm very happy with this choice, but I'd love to hear thoughts and experience from people here.(**)
    (*) In 22 years at my place I've had 3 power outages, so this is not something I'm guarding against anyway. My informal test involved a bottle of port and bravado.
    (**) Maybe not so many opinions though.. I prefer thoughts.
  • Only concern is that magnets are temperature sensitive, if enough to affect your setup I do not know.
    But thinking about it for 2 seconds, at higher temperatures the magnet should be weaker and the first layer height should increase making it a safe failure; if however during winter your ambient temperature drops you may find the opposite to be true.
    Curious to hear how you get on with different temperatures.
  • Hi,
    It it makes you happy that is all that matters.
    As you observed, micro-switches work just fine, so a person's preference then depends on other things, such as esthetics.
  • @bearer said in Reed switch endstops. Anybody else using them?:
    Interesting point, I've also got expansion in the 2020 columns to consider, never given that much attention. I guess the Delta grows fractionally as she heats, could be worth setting a dial gauge up above a column and seeing what happens. My printroom is dry, fan ventilated and stable in temperature.
  • For reference (since there is fluff on my photo, sorry) the unit is a ms-213-3-1-0500, shows up like a rash in searches.
    I just discovered this, from the manufacturers website. In particular:
    How to achieve highest switching accuracy
    • Magnetic field should be "spot focussed" towards the contact area of the Reed Switch. Providing single pole actuation, smallest possible switching difference is the result.
    • Lowest hysteresis of Reed Switch is recommended since difference in switching distance between ON and OFF is very small for this type
    • The less tolerances for the magnet and Reed Switch, the better
    I'm at a loss over the last line.. but the rest makes me think I need to redesign my carriage brackets with the magnets mounted vertically, I got the maximum range in this parallel configuration but seeing their argument about 1 pole vs both makes me think I should change the magnet orientation.
    @fcwilt said in Reed switch endstops. Anybody else using them?:
    Very much agree, I can also see the attraction of something complex, the hall effect sensors have bi-colour leds on them, which is also cool (I quite like flashing lights on futuristic things, too much SciFi in my youth).
  • @EasyTarget said in Reed switch endstops. Anybody else using them?:
    oh, just in case youre thinking of taking a heatgun to your printer to test; don't . magnets will permanently demagnetize if heated above their Curie temperature, which is usually somewhere between 80 to 150C.
    I was thinking of positioning the dial gauge on a convenient shelf so it is touching the column top, and then putting my printbed to 70C and leaving it for half an hour to see how the needle shifts from the index. Eg seeing what happens in realistic scenarios, applying direct heat would be silly, and unrepresentative.
    Im not worried about Curie temperatures; in this case it is 400C, though field strength will decrease well before that of course.. It should be acceptable over the temperature range I can expect.
    The printer which I'm working on has end switches that looks exactly same.
    They are triggered by magnets. When magnet is away switch is open (infinite resistance). Magnet close - switch is closed (resistance under 1 ohm)
    But how exactly did you plug them in the board?
    I plugged mine to +3.3V and to io.in of IO_0, IO_1, IO_2 but somehow when I'm in "Machine specific" page Endstops table doesn't show Yes when it should...
  • I would expect snap microswitches to be a LOT more repeatable than reed switches.
    Sorry, I think you took a big step backwards.
    If your preferences lean toward magnetic, sealed, etc. Hall effect sensors are the way to go.
  • I never had any luck with Reed switches. They aren't very reliable from experience
  • I have a 3DS Cubex Duo that came with reed switch endstops installed.
  • @monster said in Reed switch endstops. Anybody else using them?:
    I mean end switches on my BFB are exactly as on this topic picture:
    Quite frankly I'm not sure is it reed or Hall effect, I just thought if that would be a Hall then it wouldn't be sharp step from indefinite resistance to almost zero. But anyway those switches were functioning very well under original BFB controller. And they look cool 😁 hehe and very nicely integrated into construction.
    So I got to go with those at least for now.
    My problem for the moment is I can't get Duet 3 to see them. I'm sure I did not right connection 😞
    I did plug them in IO_0, IO_1, IO_2
    1 wire to 3.3 another wire to io.in - that seemed logical (to me πŸ™‚ ) as switch closes --> 3.3 volts comes to io.in and controller can sense that end point reached.
    Though :
    Or is there an additional configuration needed before it can be seen in here?
    Or should that be not 3.3 but rather 5v pin?
    Hall effect sensors have 3 wires, not 2.
    Reed switches are normally-open so when using RRF3 you will need to use S1 and invert the pin name in the M574 command.
  • @dc42 said in Reed switch endstops. Anybody else using them?:
    Ups πŸ™‚
    Good to know πŸ˜‡
    1 wire to 3.3 another wire to io.in - that seemed logical (to me ) as switch closes 3.3 volts comes to io.in and controller can sense that end point reached.
    firstly you'll need to know what type of switch it is; but if i goes "indefinite resistance to almost zero" lets assume it functions as an normally open* switch. in that case you need to connect it between ground and the input pin.
    *)suppose it could be normally closed, depends on the state your description started off in
    Ah! It is ground and input pin!?
    Well that might explain everything!!! I didn't know it works that way!
    You see how bad am I 😭
    for swithces, yes. (inputs uses a pull up resistance so it is normally 3.3v, as such connecting the other end to 3.3v never has any effect)
  • Wooohooo! Got it!
    End stops are working now!
    1. I did reconnect as @bearer said πŸ‘
    2. I did some googling/reading and find out that "M574 X1 Y1 Z1 S1 " is depricated. Added separate lines for each.
    3. UI was replying that pins need names and then I found an example on forum with names like P"xstop" - used it
    4. Then UI was replying that names are wrong. I was banging my head for a bit πŸ€•
      And then found: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_Num_3
    Here is how it looks
    ;M574 X1 Y1 Z1 S1                                ; set active low and disabled endstops
    M574 X1 S1 P"!io0.in"
    M574 Y1 S1 P"!io1.in"
    M574 Z1 S1 P"!io2.in"
  • I found this repeatability test
    https://bbs.homeshopmachinist.net/forum/general/29522-reed-switch-repeatability-test-for-cnc
    which suggests a repeatability of +0.01-0.03 mm.
    However, using stronger magnets absolutely does NOT improve the repeatability because the switch just triggers farther away. The magnetic field isnΒ΄t any more "defined" at the triggering distance.
    IΒ΄d like to know how differing environmental influences affect the triggering distance, i could imagine EMI could drastically change that.
    All in all it would be too much of a risk for my liking only to get the novel factor.
  • I think it would be interesting to see how it behaves when it's mounted close to a stepper that is actively stepping. You'd think the motor design would contain the field from the coils/magnets fairly well, but it probably doesn't take too much "leakage" to close a reed switch.
