UNSOLVED External Drivers - Duet 2 inputs and outputs for Homing?
  • I am using a Duet 2 to run a linear servo motor driven by an external driver (Granite Devices "Argon" - https://granitedevices.com/wiki/ARGON_Servo_Drive ).
    In my mind, I need two things for homing:
    1). Duet Tells Argon to Home (Output from Duet)
    2). Argon tells Duet that homing is complete (Input to Duet)
    Is this thinking correct? If so, what I/O on the Duet board could I use for this?
