G32 w BLTouch and Z-endstop
Hey!
Finally upgraded to a duet 2 wifi from an Smoothieware on a MKS SBase 1.3 and i'm having some issues with my BLTouch. I'm running a BLTouch v3 and a Z-min endstop on a Hypercube with the 220x220 dimensions.
I've got it wired up and can trigger the BLTouch with the following commands:
Pin down: M280 P3 S10 I1
Pin up: M280 P3 S90 I1However, when i run G32 for auto bed leveling the printer goes to X135 and Y10 and then tries to probe the bed. The first probe is fine, but then the alarm is triggered and it failes:
Error: Z probe was not triggered during probing move
Here's a video showing the problem. I'm executing the G32 command.
https://imgur.com/a/HOQz1KXAny ideas?
I'm adding my config.g:
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.0.5 on Thu Oct 31 2019 00:59:28 GMT+0100 (centraleuropeisk normaltid) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Hypercube" ; set printer name M667 S1 ; select CoreXY mode ; Network M551 P"password" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes backwards M584 Y0 X1 Z2 E3 ; set drive mapping M350 X256 Y256 E256 I0 ; configure microstepping without interpolation M350 Z16 I1 ; configure microstepping with interpolation M92 X1280.00 Y1280.00 Z400.00 E6984.63 ; set steps per mm M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1300 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X200 Y200 Z150 S0 ; set axis maxima ; Endstops M574 X1 Y1 Z1 S0 ; set active low and disabled endstops ; Z-Probe M557 X5:170 Y5:170 S20 ; Define mesh grid M558 P9 H5 F1000 T4000 X0 Y0 Z0 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves G31 P25 X30 Y15 Z5.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment ; Heaters M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H3 A-1 C-1 D-1 ; Disable the 3th Heater to free up PWM channel 5 on the Duex board. M307 H4 A-1 C-1 D-1 ; Disable heater 4 to be used to control brush servo ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P2 C"FAN3" S0 I0 F500 H-1 ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F-1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
May i ask why G32 and not G29?
https://duet3d.dozuki.com/Wiki/Gcode#Section_G29_Mesh_bed_probe
I'm used to G32 from Smoothie.
Just tried G29 and it does the exact same as in the video..
Did you create the deployprobe.g and retractprobe.g files?
G32 has it's uses for bed leveling but for creating the height map used by mesh compensation (which deals with bed irregularities) you use G29.
Thanks! I'll start using G29 instead.
Yes, i've created the two files:
Deployprobe.g
M280 P3 S10 I1Retractprobe.g
M280 P3 S90 I1
So all is working now?
No.
I had the two files already and i'm getting the same result (as in the video) with G29.
When I specified the area to be probed I had to take into account my Z-probe offsets.
I've also done that, see the config above.
@jontek2 said in G32 w BLTouch and Z-endstop:
Well you are cutting the X axis a bit close but I guess it's ok.
Clearly something is wrong as the probe is deployed while moving.
Do M401 and M402 work correctly?
The M401 did deploy the probe and M402 retracted it.
Any examples of how your BLTouch is configured?
Could I have wired it wrong?
Either there is something wrong with the wiring, however i doubt that since all of the commands are working.
Therefore it must be something wrong with the configuration.
What i've done is:
Wired the BLTouch
Added the two files
Added the following code:; Z-Probe M557 X5:170 Y5:170 S20 ; Define mesh grid M558 P9 H5 F1000 T4000 X0 Y0 Z0 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves G31 P25 X30 Y15 Z5.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
Is there something i'm missing?
Hmm...
You have X0 Y0 Z0 parameters in M558.
According to the docs they are obsolete so try removing them.
And if you are not using the most recent firmware upgrade and see if that makes a difference.
Thanks. There's seems to be an update to it in the latest firmware.
I just redid all of the wiring to the BLTouch and got it working
The crimping must have gone bad in one of the signal-wires.
But got some new errors:
Warning: Skipping grid point (0.0, 0.0) because Z probe cannot reach it
It should be able to probe at 0, 0 since the offset is 30 and Y.
M557 shows X5:170 Y5:170 S20
Why is it now trying to probe 0, 0?
Ok, here's an update:
I've got everything to work with the BLTouch and my config now is the following:
; Z-Probe M558 P9 H5 F100 T2000 ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves G31 X30 Y15 Z1.688 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
However i'm getting the following message when i'm trying to do a G29
Error: G29: No valid grid defined for bed probing
My "Define Area for Mesh Grid Compensation" is the following:
Start coordinate in X direction: 0
End coordinate in X direction: 210
Spacing in X direction: 20
Start coordinate in Y direction: 0
End coordinate in Y direction: 210
Spacing in Y direction: 20However, if try to enter G29 two more tries - it works. Is this a known bug or am I doing something wrong?
What happened to M557 X5:170 Y5:170 S20?
170x170 was something i had in size from Smoothie.
seemed to be something from an earlier firmware version.
I would put it back. It is taking into account the z-probe offsets, as it should.
Though I would be inclined to use X5:165 and Y5:185 to keep the z-probe away just a bit from X and Y max.
According to the documentation (https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe) the M557 commands is used for the Touch-Mi.
That is simply mentioned there because of the characteristics of that type of probe.
M557 is used to specify the area to be probed for mesh compensation.
From the docs:
M557: Set Z probe point or define probing grid
Parameters to define G29 probe grid (all values in mm)Xaaa:bbb Minimum and maximum X coordinates to probe
Yaaa:bbb Minimum and maximum Y coordinates to probe
Raaa Radius to probe
Saaa Probe point spacing (RepRapFirmware 1.19beta10 and later also support Saaa:bbb)
Pnn or Pxx:yy (RRF 2.02 and later) Number of points to probe in the X and Y axis directions (alternative to specifying the probe point spacing)
Hmmm then why are there a function in the GUI for "Define Area for Mesh Grid Compensation"?
Does the same thing.
Using the command is my approach.
I have two macros for running mesh compensation.
The first sets up a simple 4 point grid just to get a quick view of the overall levelness of the bed. I first did this when I was leveling the bed manually.
The other is for the full mesh compensation using points on a 20x20 grid.
Each macro uses the M557 command to specify the desired grid.
With the most recent DWC using the menu option to specify the grid mentions the M557 command.
Alright, i'll look in to that.
What's your start G-codes? Do you run the G29 in the start G-code?
I'm currently using:
;;; STARTING SCRIPT BEGIN ;;; G28 ; Home G29 ; Bed leveling G92 E0 ; Zero extruder G1 X120 E20 F600 ; Draw prime line ;;; STARTING SCRIPT FINISH ;;;
Currently I only run bed leveling (G32) and mesh probing (G29) manually from macros for two reasons.
They take a while and the printer seems to be doing well with just doing those processes occasionally.
My Z homing procedure...
- clears mesh compensation
- cancels any "baby-stepping"
- homes using a end stop switch
- sets the Z=0 datum using a BLTouch Z-probe
- loads the most recent full bed mesh compensation file
This happens whenever Z is homed so the normal "begin print" process doesn't need any special actions related to them, it just does the normal things related to set temps, selecting tools, priming and cleaning nozzle, etc.
