RepRapFirmware 3.0beta12 now available
    I've just released this at https://github.com/dc42/RepRapFirmware/releases/tag/3.0beta12. The release notes are there too.
  • Silly question ... RepRapFirmware 3 is only for Duet 3, where he can turn on Duet 2.
  • It's work on duet 2
  • M143 was not (officially) supported in beta 11 (according to the changelog and the upgrade guide)
    Beta 12 does not specify this limitiation, but does not list the addition of support in the changelog either.
    So my question is, does beta 12 support M143?
  • Installed on Duet3 Hardware. Homing looks much better.
    Is there an update for Duet 3 expansion boards?
  • What are the changes for users of duet 2 firmware 2.04?
  • If you mean "what do I have to change to upgrade"...
    https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
  • about to place an order for a duet 3 mainboard for a cnc build and just would like to clarify that the configuration may have a tab for cnc? i feel this is a very worthy tool for the machine and it would unlock many more options for expand ability in the future for maybe tool changing or laser /plasma cutting.... or even 5-6 axis machining
  • Moderator
    @denke said in RepRapFirmware 3.0beta12 now available:
    There has been no change regarding M143 in the source code since beta 11.
  • @dc42 Is there a roadmap anywhere? I'm just curious as to what the development plan is, what's being worked on and what might possibly be coming down the line. Not expecting any timescales obviously, I'm just intrigued by the whole process.
    M143 is implemented but not tested yet - and in my book, untested code is broken code.
    The priorities for RRF3 development are:
    • Complete the support for expansion boards on Duet 3
    • Conditional GCode and object model
    • Add a few missing features
  • Conditional GCode sounds amazing and incredibly powerful, look forward to that one. Thanks for the update.
  • @dc42 Thanks for this rough roadmap.
    could you tell us what is the plan for 3HC expansion board ?
    Because Can-FD is promissing if all features are working on 3HC (Z probe / servo / Thermocouple ...)
    Conditionnal Gcode sounds great too, even I prefer to have features working first 😉
    The following items connected to expansion boards work in beta 12:
    • Stepper motors, temperature sensors (inc. thermocouple and PT100 but not DHT), heaters (but not heater protections, and not heaters controlled by sensors on a different board), fans (including tacho readings, but excluding fans thermostatically controlled by sensors on a different board).
    In the current committed source code, endstop switches are also working; but I need to add a safety feature before I release that.
    The following are either not implemented on expansion boards or implementation is in progress, and therefore not working yet:
    • GPIO output (M42), servo output (M280), trigger inputs, stall detection endstops, Z probes, reporting of stepper driver errors and warnings, additional diagnostics inc. crash reports.
    Assuming no component shortages, I estimate that first deliveries to the 3HC to customers will be 5 to 6 weeks from next Monday. So we may just miss delivery before Christmas, in which case deliveries won't start until after New Year. We'll have a better idea next week and we may open a pre-order.
  • @dc42 thanks for this detailed answer, End of the year sounds Great ! I will that closed to a Christmas Beer 😉
    Endstops are now working on expansion boards, using the main+expansion firmware builds at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
  • I still miss a fix for the tool changer scripts, that the Z axis is not moving while tool changing. Also happens on 2.xx
    @smoki3 said in RepRapFirmware 3.0beta12 now available:
    Please provide a link to the post where you described this. Or, if it is in a thread with lost of other stuff, start a new thread.
  • @dc42 said in RepRapFirmware 3.0beta12 now available:
    Bug in 2.03, 2.04RC1 and latest 3.0 beta: https://forum.duet3d.com/topic/11343/new-reprapfirmware-3-0-early-beta/30
    Its already on the bug list. but its a bit hidden. You may have fogotten 🙂
    I copied the conversation in this thread:
    https://forum.duet3d.com/topic/12920/tool-change-moving-in-axis-without-calling-them
    Thanks, I'll put further responses i that thread.
  • @dc42 yes :)! I hope I don’t miss the pre-order
  • M308 S1 Y"rtdmax31865" P"spi.cs1" A"RTD1"
    M950 H1 C"e0heat" T1                                    ; create nozzle heater output on e0heat and map it to sensor 1
    M143 H1 S360                                            ; set temperature limit for heater 1 to 360C
    M307 H1 B0 S1.00                                        ; disable bang-bang mode for the nozzle heater and set PWM limit
    M308 S2 Y"rtdmax31865" P"spi.cs2" A"RTD2"
    M950 H2 C"e1heat" T2                                    ; create nozzle heater output on e1heat and map it to sensor 2
    M143 H2 S360                                            ; set temperature limit for heater 2 to 360C
    M307 H2 B0 S1.00                                        ; disable bang-bang mode for the nozzle heater and set PWM limit
    Does the above look right for a pair of PT100 sensors plugged into the PT100 Daughter board on a Duet 2 Wifi?
    The second tool appears correct, but the first is stuck at ~210°C (even though it's cool to the touch).
    I'm also struggling to work out how to have a fan be thermostatically controlled by mcutemp, which I'm pretty sure I had in V2 (though, I may be mistaken).
    @keyz182 said in RepRapFirmware 3.0beta12 now available:
    Yes, that looks correct. What reading do you get if you connect the 100R resistor to the second input instead of the PT100?
    Create a sensor for mcutemp, then use that sensor number ni the H parameter of your M106 command. In RRF3 the M106 H parameter refers to a sensor number, not a heater number.
    Just been fiddling around - it appears it may be a connection issue (reading varies a lot, even going up to 2000C based on touching the wire), so going to check/rewire that first. Will check the 100R if I have one.
    Ahh, gotcha. Thanks.
