G32 G30 Auto Calibration Issues
I'm in the midst of converting an Anycubic Kossel Linear Plus to Duet electronics and Haydn's magball arms. I am having difficulty with getting the auto-calibration to work properly, and I'm sure it's a very simple thing I have overlooked, but I've been stuck for a few days.
Running G28 followed by G30 produces results as expected. Tap the nozzle, probing stops.
When running G32, the effector descends, will not respond to Z-probe trigger, and crashes into the bed. Occasionally, when running calibration with a test height of M665 H100 instead of the H240 approximation I have below from my initial build and measurements, the effector will descend ~100mm, perform a Z probe going down 20mm dive height as specified in M558, not make contact with the bed, and fail the calibration due to no measurements.
I think I've included relevant information below. Let me know if there's any other information you need or if you have questions. Thanks!
TLDR, how do I stop my G32 from ignoring my z probe output and crashing into the bed?
Firmware Version: 2.04 (2019-11-01b1)
Note that I was running an older version of the firmware when first encountering this problem, but updating to the newest release did not solve my issue either;bed.g M561 G28 G30 P0 X0.00 Y100.00 Z-99999 H0 G30 P1 X86.60 Y-50.00 Z-99999 H0 G30 P2 X-86.60 Y-50.00 Z-99999 H0 G30 P3 X0.00 Y50.00 Z-99999 H0 G30 P4 X43.30 Y-25.00 Z-99999 H0 G30 P5 X-43.30 Y-25.00 Z-99999 H0 G30 P6 X0 Y0 S4
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.0.5 on Thu Oct 31 2019 11:01:24 GMT-0700 (Pacific Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"delta" ; set printer name M665 R130 L288.13 B110 H240 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X80 Y80 Z80 E96 ; Set steps per mm M566 X300 Y300 Z300 E300 ; Set maximum instantaneous speed changes (mm/min) M203 X1200 Y1200 Z1200 E12000 ; Set maximum speeds (mm/min) M201 X3000 Y3000 Z3000 E3000 ; Set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X1 Y1 Z1 S1 ; set active high endstops ; Z-Probe M558 P8 R0.4 F1200 H20 ; set Z probe type to effector and the dive height + speeds G31 P100 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height M557 R85 S20 ; define mesh grid ; Heaters M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4725 C7.06e-8 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 S"Hotend" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
This post is deleted!
@whil said in G32 G30 Auto Calibration Issues:
G30
Running G30 should give you the height to put into M665.
Change your bed.g to run 6 factor calibration. (the default recommended one -> S6).
Normally there is no G28 in the Bed.g file
I think both of us might be confused here. Correct me if I'm wrong, but when G30 is called during auto calibration, triggering the Z probe should stop the effector. Correct? Currently, this is not the case with my setup.
home the printer
run M119
report the output.move the head down to where it should trigger.
then run M119 again
report the output.
