How to change something in file resurrect.g?
1.7k
  • undefined
    DSG
    The end of resurrect.g file that was created automatically by system after power failure or planning power off (pause) has some code to move the print head to previous location before power fail. I do not want the print head move up 2mm before resume printing. I must edit the resurrect.g file manually before resume print. How can I config that?
    Thanks!
    • undefined
      DSG
      Anyone can help me?
      • undefined
        Can you post a sample of the resurrect.g?
        • undefined
          DSG
          My resurrect.g is below:
          ; File "0:/gcodes/prusaslicer/prusaslicer-test bed.gcode" resume print after print paused at 2019-11-05 10:18
          G21
          G29 S1
          T-1 P0
          G92 X5.000 Y157.500 Z0.150
          G60 S1
          M98 P"resurrect-prologue.g"
          M116
          M290 X0.000 Y0.000 Z0.000 R0
          G10 L2 P1 X0.00 Y0.00 Z0.00
          G10 L2 P2 X0.00 Y0.00 Z0.00
          G10 L2 P3 X0.00 Y0.00 Z0.00
          G10 L2 P4 X0.00 Y0.00 Z0.00
          G10 L2 P5 X0.00 Y0.00 Z0.00
          G10 L2 P6 X0.00 Y0.00 Z0.00
          G10 L2 P7 X0.00 Y0.00 Z0.00
          G10 L2 P8 X0.00 Y0.00 Z0.00
          G10 L2 P9 X0.00 Y0.00 Z0.00
          G54
          G10 P0 S190 R190
          T0 P6
          M106 S0.00
          M106 P0 S0.00
          M106 P3 S0.00
          M106 P4 S0.00
          M106 P5 S0.00
          M106 P6 S0.00
          M106 P7 S0.00
          M106 P8 S0.00
          M116
          G92 E0.00000
          M83
          M23 "0:/gcodes/prusaslicer/prusaslicer-test bed.gcode"
          M26 S459 P0.000
          G0 F6000 Z2.150
          G0 F6000 X5.000 Y157.500
          G0 F6000 Z0.150
          G1 F6000.0 P0
          G21
          M24
          And the lines that I want to delete
          G0 F6000 Z2.150
          G0 F6000 Z0.150
          Add some code at the end of it.
          How can I figure that? Not modify manually.
          • undefined
            Thanks for the sample. What firmware version?
            • undefined
              DSG
              My board is duet2wifi rev1.04 using firmware 2.03
              • undefined
                I'm not sure if it's related, but there were some changes to the resurrection behaviour in the recently released 2.04 firmware update. Perhaps you can give it a try.
                https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
                undefined 1 Reply Last reply 6 Nov 2019, 01:41 Reply Quote 0
                • undefined
                  DSG @Phaedrux
                  @Phaedrux the last update 2.04 just fix the select tool before resurrect-prologue.g is called.. I think it is not that I need, but I will try.
                  Thanks for your support.
                  • undefined
                    What's in your prologue file?
                    undefined 1 Reply Last reply 6 Nov 2019, 01:58 Reply Quote 0
                    • undefined
                      DSG @Phaedrux
                      @Phaedrux prologue file just
                      M116
                      G28 X Y
                      • undefined
                        Thanks.
                        Perhaps @dc42 will have some insight.
                        • undefined
                          blt3dp
                          How are you testing? Manually pausing or pulling the power? If your pausing it, what you're looking for might be in pause.g pause.g
                          My 3D Printing YouTube Channel
                          Better Living Through 3D Printing
                          Follow me on Instagram and Twitter
                          Instagram
                          Twitter
                          • undefined
                            littlehobbyshop
                            After a skim of the firmware, unfortunately this 2mm lift is hard coded and isn't configurable:
                            Line 2310 in /src/GCodes/GCodes.cpp:
                            https://github.com/dc42/RepRapFirmware/blob/2af0feba89833b8631dac6a3e662d4fc13f40410/src/GCodes/GCodes.cpp#L2310
                            The only way you would be able to change it is to fork the repo and re-compile your own version.
                            Perhaps you could also add an issue as a request for this to be configurable? No idea how that would be implemented and it may well be too much development for a fringe case.
                            BLV MGN Cube w/Hemera, K8200, Sunlu S8
                            undefined 1 Reply Last reply 9 Nov 2019, 09:52 Reply Quote 1
                            • undefined
                              T3P3Tony administrators
                              @DSG what is your M911 command set to:
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_M911_Configure_auto_save_on_loss_of_power
                              www.duet3d.com
                              undefined 1 Reply Last reply 8 Nov 2019, 15:28 Reply Quote 0
                              • undefined
                                DSG @T3P3Tony
                                @T3P3Tony just turn off the motor X Y and retract follow the guide in wiki.
                                undefined 1 Reply Last reply 8 Nov 2019, 15:44 Reply Quote 0
                                • undefined
                                  T3P3Tony administrators @DSG
                                  @DSG the guide in the wiki has a Z parameter added in the M911 command, hence why I asked
                                  www.duet3d.com
                                  undefined 1 Reply Last reply 9 Nov 2019, 09:51 Reply Quote 0
                                  • undefined
                                    DSG @T3P3Tony
                                    @T3P3Tony yes, wiki has guide that but I do not add the z lift code to M911, just turn off X Y motor and retract.
                                    • undefined
                                      DSG @littlehobbyshop
                                      @littlehobbyshop please tell me how to compiled firmware. Thanks!
                                      undefined 1 Reply Last reply 9 Nov 2019, 11:08 Reply Quote 0
                                      • undefined
                                        dc42 administrators @DSG
                                        @DSG, can you tell me why you want to delete those 2 lines? Those lines are intended to move the head back to the point where it was when the power fail occurred, without scraping the top of the print.
                                        The firmware build instructions are at https://github.com/dc42/RepRapFirmware/blob/dev/BuildInstructions.md.
                                        undefined 1 Reply Last reply 10 Nov 2019, 01:51 Reply Quote 0
                                        • undefined
                                          DSG @dc42
                                          @dc42 the lifting z about 2mm make the resume print not fit with the exist printed object. I have successed with remove lift z code in the resurrect.g not only pause state but also power failure. Have you added this mod in the next firmware version (user can figure the movement of print head)?
                                          undefined 1 Reply Last reply 10 Nov 2019, 11:48 Reply Quote 0
                                          9 out of 26
