    Duet Ethernet MAC address
    duet ethernet mac address network
    • Bewarenundefined
      Bewaren
      Hey I'm a uni student an my accommodation requires the mac address of any device to be added to their network, I'm trying to add my printer too this network but when using command M540 to aquire the address I get what I would say is a valid MAC address but when I enter it too the system it says its invalid, any ideas?
      The address I'm getting is: be:7c:3a:30:52:3e
        You could use M540 to specify your own mac address if you can find one that the system accepts.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M540_Set_MAC_address
        Bewarenundefined 1 Reply Last reply Reply Quote 0
        • Bewarenundefined
          Bewaren @Phaedrux
          @Phaedrux what would the command be to use then? M540 (New MAC Address)? And what should I input that into? YAT?
            @Phaedrux said in Duet Ethernet MAC address:
            M540: Set MAC address
            Parameters
            Pnnn The MAC address
            Examples
            M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED
            M540 PDE:AD:BE:EF:CA:FE
            You'd put that command into your config.g so that it was executed at startup.
            But now looking at the examples, it reminds me that there are 2 ways to express a mac address. Perhaps your network is looking for the 0x method.
            • T3P3Tonyundefined
              T3P3Tony administrators
              what is the system the university is using to determine what a valid MAC address is? I assume its not jsut a formatting issue (you added your Laptop etc i expect?) they may have a database of mac address ranges assigned to "valid" devices and don't allow arbitrary MAC addresses (for "security")
              you could try setting it to
              0D:1E:15:30:52:3e
              and then adding that to the network...
              That is a Mac address from within the HP range i think. If that works then you know its something in their tool that allows certain mac addresses and not others
              www.duet3d.com
              • A Former User?
                A Former User @Phaedrux
                much more than 2 when it comes to formatting of MACs. Microsoft uses - instead of : to separate hex bytes, pluss countless variations on binary hexadecimal and octal representations
                I'd discourage using MAC addresses with the unique/local but set to unique for an address outside your organisations control as it could (theoretically) break networks. If deemed absolutely necessary for testing try using an address for equipment you own and know is not connected to avoid problems. Even if you know the address isn't on your broadcast domain you rarely have control over the other broadcast domains of neighboring layer 3 devices which could be affected. And make sure to revert the address to the original or a locally administered one as soon as possible.
