Done something to my config, now all tools are gone.
Not sure what I have done here but I had two tools set up with the exception of the drives. I was able to get the heaters working correctly and showing the temps but when I went to extrude some filament neither one would work so I went to my config to see if I had something set wrong. Now all my tools have disappeared and I can't figure out what is wrong.
I am sure it is something simple but cannot see it.
Set up:
Duet Wifi & Duex5
Firmware version 2.02
Web interface 1.22.6First extruder is using:
Drive 5 on Duex5
Heater 3 on Duex5
Thermistor 3 on Duex5Second extruder is using:
Drive 6 on Duex5
Heater 4 on Duex5
Thermistor 4 on Duex5Config:
;General preferences*******************************************************************
M669 K1 ; Select CoreXY mode;Axis Limit*******************************************************************
M208 X355 Y355 Z400 S0
M208 U0:180 ; Set axis maxima;Endstop Settings*******************************************************************
M574 X1 Y1 S1 ; Set active high endstops
M574 U1 S1 ; Set homing switch configuration for toolchange lock. Both switches should be wired NC and in series.;Z-Probe*******************************************************************
M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 F100 H5 R0.2 T6000 B0 ; Set Z probe type to BLTouch and the dive height + speeds
G31 P25 X-3 Y-39.3 Z0.4 ; Set Z probe trigger value, offset and trigger height
M557 X15:350 Y20:350 S2 ; Define mesh grid;Drives*******************************************************************
M584 X0 Y1 Z2:3 E5:6 U4 ; Drive mapping
M569 P0 S0 ; X Drive 0 goes forwards
M569 P1 S1 ; Y Drive 1 goes backwardsM569 P2 S1 ; Z1 Drive 2 goes backwards
M569 P3 S1 ; Z2 Drive 3 goes backwardsM569 P4 S1 ; U Drive 4 goes backwards
M569 P5 S0 ; E0 Drive 5 goes forwards
M569 P6 S0 ; E1 Drive 6 goes forwards;M569 P7 S0 ; NOT USED
;M569 P8 S0 ; NOT USED
;M569 P9 S0 ; NOT USEDM350 X16 Y16 Z16 E16:16 U16 I1 ; Configure microstepping with interpolation
M92 X66 Y66 Z1600 E443.62:443.62 U100 ; Set steps per mm
M566 X250 Y250 Z300 E1000:1000 U100 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
M203 X30000 Y30000 Z400 E4000:4000 U5000 ; Set maximum speeds (mm/min)
M201 X800 Y800 Z20 E1000:1000 U800 ; Set accelerations (mm/s^2)
M906 X1200 Y1200 Z1300 E300:600 U1500 I30 ; Set motor currents (mA) and motor idle factor in percent
M84 S30 ; Set idle timeout;Heaters*******************************************************************
M305 S"BED" P0 T100000 B4138 C0 ; Set thermistor
M143 H0 S225 ; Set temperature limit for heater 0 to 225CM305 S"T0" P3 R4700 T100000 B4388 ;Set thermistor
M143 H3 S300 ; Set temperature limit for heater 3 to 300CM305 S"T1" P4 R4700 T100000 B4388 ; Set thermistor
M143 H4 S300 ; Set temperature limit for heater 4 to 300C;Tools*******************************************************************
M563 P0 S"T0" D5 H3 ; Define tool 0
G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets
G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0CM563 P1 S"T1" D6 H4 ; Define tool 1
G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets
G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C;tool offsets
G10 P0 X9 Y39 Z0 ; T0
G10 P1 X9 Y39 Z0 ; T1
;G10 P2 X-9 Y39 Z-5 ; T2
;G10 P3 X-9 Y39 Z-5 ; T3;Fans*******************************************************************
;M106 P0 S0 I0 F500 H-1 ; UNUSED
M106 C"T0 FAN" P3 S255 I0 F500 H3 T70 ; T0 HE
M106 C"T0 LAY FAN" P4 S0 I0 F500 H-1 ; T0 PCF
M106 C"T1 FAN" P5 S0 I0 F500 H4 T70 ; T1 HE
M106 C"T1 LAY FAN" P6 S0 I0 F600 H-1 ; T1 PCF
;M106 P7 S0 H3 T70 ; T2 HE
;M106 P8 S0 ; T2 PCF -
I'm a bit confused.
In your 1st M563 you specify tool 1, name it tool 0 and comment it as tool 2.
in you 2nd M563 you specify tool 2, name it tool 1 and comment it as tool 3.
And why is there no M562 for tool 0?
So what is going on there?
Check now, I fixed the names
Just did a Firmware Diagnostics and shows that the Drives 5-9 are not available... What would cause that?
Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 0/203
Driver 1: standstill, SG min/max 11/253
Driver 2: standstill, SG min/max 0/346
Driver 3: standstill, SG min/max 0/263
Driver 4: standstill, SG min/max 0/398
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Driver 8: standstill, SG min/max not available
Driver 9: standstill, SG min/max not available
Date/time: 2019-11-09 21:20:52
Cache data hit count 2022493585
Slowest loop: 6.65ms; fastest: 0.07ms -
OK so still no tools?
Off topic but thought I would mention it.
I would update to firmware 2.04.
Regards M208: There is a "short form" now M208 Xmin:max keeping all the values together in one command.
Regards the M565/G10 "pairs": You can use just one G10 command with both sets of parameters. Again keeping things together.
Still haven't seen the problem. Will keep looking unless you find it first.
Nope still no tools.
@cdl1701yahoo-com said in Done something to my config, now all tools are gone.:
OK I will have to look again.
Upgraded Firmware to 2.04.
Just an FYI, still no tools -
Just an FYI, still no toolsWell we are missing something obvious.
I think the problem is the drive numbers in the M563 command.
I just checked my config and even though T0 is drive 3 in the M584 it is drive 0 in the M563.
I think that drive numbers in M563 start at 0 for the first extruder regardless of the drive number in M584.
Try that.
Well that got my tools back but this is how it looks on my duet panel.
If I change the H parameter to use 1 & 2 then 3 & 4 go away but still shows 2000 temp reading which is obviously wrong! haha -
I don't think the heaters change numbers.
If memory serves they are always 0,1,2 on the Duet WiFi and 3,4,5,6,7 on the Duex5.
I have a duet panel but I have never used it.
Any Idea how to get 3 & 4 to show as 1 & 2?
No I don't. Someone should.
I never used my panel - it was just easier to use the web interface.
