    Help to configure order
    Order discussion
    2328
    • njjn2020
      njjn2020 last edited by
      Hello! I plan to purchase duet ethernet + small screen for kossel printer.
      1. does it support 0.9 stepper motors?
      2. will 0.9 motor on kossel printer give higher precision?
      3. what kind of motor with your board will give more printing speed?
      4. do you sell in the US?
      thank you!
        1. Yes. You should use 24V power with 0.9deg motors, not 12V.
        2. Yes
        3. A motor with low inductance. The higher the rated current, the lower the inductance will be, so look for a motor with between 2.0A and 2.4A rated current per phase. For example, 17HM19-2004S. Longer motors will have higher inductance.
        See also https://duet3d.com/wiki/Choosing_stepper_motors.
        4. Our US distributor is Filastruder.
        • njjn2020
          thank you very much for detailed responce.
          i can not find on the site
          1. Mini differential IR height sensor
          2. PanelDue without screen
          please advise how to add those items to the cart.
          have a great evening!
          • elmoret
            elmoret last edited by
            If you mean the Filastruder site:
            https://www.filastruder.com/products/mini-differential-ir-height-sensor
            https://www.filastruder.com/collections/electronics/products/paneldue
            • njjn2020
              and what for the UK site?
              i decided to buy directly from you. thanks!
                You can order those items directly from my escher3d.com web site. But if you are in the US, you'll get them faster if you order them from Filastruder.
                • njjn2020
                  well, i have decided that i will ship my order to russia from the uk. it will be faster and cheaper.
                  is there a way to put
                  1 duoWiFi (or Ethernet if availeble)
                  2 pannel duo without screen
                  3 IR probe
                  to one order and single shipment (instead of ordering in 3 different places). thank you!
                  • T3P3Tony
                    I am sorting out the option to order a DanelDuet w/o screen now on the website, I will write again once its done.
                    We are currently out of stock of IR probes but I am hopieng we will have some more in stock soon.
                    Duet Hardware Designer
                    www.duet3d.com
                    • njjn2020
                      ok, waiting for the integration result and IR probe availability
                      • njjn2020
                        duet3d site login function does not work.
                        "The page you requested cannot be found."
                        link - https://duet3d.com/%3C/?php%20echo%20$login;%20?%3E
                        • T3P3Tony
                          Will look into this now
                          www.duet3d.com
                          • adavidm
                            adavidm last edited by
                            Can you get to it from here:
                            https://duet3d.com/index.php?route=account/login
                            It looks like a problem with escaping php in the website code.
                            • njjn2020
                              with new link i have created new account
                              but was unable logon with account i use on forum. are those the same accounts?
                              • njjn2020
                                "my account" in the right top corner does not work either.
                                link is defective (see below)
                                https://duet3d.com/https://duet3d.com/index.php?route=account/account
                                • njjn2020
                                  any luck with duet board for screen (without screen)?
                                  • njjn2020
                                    by the way, is it possible to setup DuetWiFi without screen ?
                                      Yes, you can setup Duet WiFi using a USB connection to a PC.
                                      • T3P3Tony
                                        It should be fixed, please check
                                        www.duet3d.com
                                        • T3P3Tony
                                          Also the product page for the PanelDue has been updated. IR probes will be back in stock soon
                                          www.duet3d.com
                                          • T3P3Tony
                                            IR probes are now back in stock
                                            www.duet3d.com
                                            • njjn2020
                                              please fix site authentication issue.
                                              1. ID from forum does not work for shopping (" Warning: The E-Mail Address was not found in our records, please try again!")
                                              2. i have created different ID for shopping
                                              3. forgot new password and used "reset password" form
                                                response: " An email with a confirmation link has been sent your email address."
                                              4. got link in the email and created new password
                                                response: " Password succesfully updated "
                                              5. used my email (from newly created account) and new password to login - FAILED
                                                response: " Warning: No match for E-Mail Address and/or Password."
                                              in fact, i tried changing password 3 times. all attempts failed.
                                              • njjn2020
                                                meanwhile some tech questions (was not able to find on the site)
                                                1. are all fans output for 5 volt ?
                                                2. there are two "always ON fans". are they also 5v? do they support PWM or other type of speed control?
                                                3. accepting 0.9 deg motors means 24v power supply.
                                                  are there 12v outputs on the board (i need it for LED light)?
                                                thank you!
                                                  1. There is a jumper that allows you to set the fan voltage supply to either 5V or VIN. The jumper affects the voltage supplied to all fan outputs.
                                                  2. The always-on fan outputs do not support PWM.
                                                  3. There is no 12V output on the Duet. There is on the DueX expansion boards.
                                                  • njjn2020
                                                    thanks for answers.
                                                    please help me to fix login issue for shopping. 🙂
                                                    • T3P3Tony
                                                      Hi i have emailed you back.
                                                      www.duet3d.com
