Where is the blue led?
Where is the blue led referred to to in the guide? : https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
Picture of the wifimodule on my duet-board:
Thats not the standard wifi module so it may not have one
@Eddas It is where the internal antenna of the Wifi modules was (the curved lines which overhang the PCB circuit board). You have a modified version with external antenna and the Wifi module is ESP-07S instead of the standard ESP-12S, the LED is removed together with the internal antenna. Just google for Duet 2 Wifi images how a standard Duet 2 Wifi look like.
According to https://forum.duet3d.com/topic/2825/converting-the-duet-wifi-to-use-an-external-antenna/13 this modification with ESP-07S is ok.
Do you know if the guide still works for this version of duet wifi?
This post is deleted!
@Eddas said in Where is the blue led?:
The guide still works for the external antenna version, except that there is no blue LED on the WiFi module to tell you its status.
I've added the following to the first point of step 6 of the guide https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s9 :
Duets with an external antenna use a different WiFi module, with no indicator LED.
