UNSOLVED H-Bot Endstop problem
Hi everybody,
This is Norbert from Germany and I hope, anybody can help me. I've seen others have similar problems but nothing helped me.
My Board is Duet ethernet with firmware 2.04. I am using inductive NPN sensors for x,y and z axis.
The motors are running into the correct directions. Z-Axis is working fine.
When I push the x- and y-axis towards the sensors the LED on the Board are illuminating and M119 says X and Y are in Home position. If I push it away it says they are not stopped.
When I try to home the Axis the Steppers don't stop. Here are my homing files:homex:
G91 ; relative positioning
G1 H2 Z5 F9000 ; lift Z relative to current position
G1 H1 X-395 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F9000 ; go back a few mm
G1 H1 X-395 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F9000 ; lower Z again
G90 ; absolute positioninghomey:
G1 H1 Y-295 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F9000 ; go back a few mm
G1 H1 Y-295 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioninghomez (Which works)
G91 ; relative mode
G1 S1 Z105 F300 ; move Z towards the switch until it triggers
G1 S2 Z-5 F100 ; move Z back 5mm
G1 S1 Z10 F100 ; move Z slowly towards the switch until it triggers
G90 ; back to absolute modeAnd config.g
M669 K1 ; switch to CoreXY mode
M552 S1 P172.21.163.110 ; enable network
M553 P255.255.255.0
M554 P 172.21.163.2M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S1 ; physical drive 2 goes backwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X32.00 Y32.00 Z640.00 E460.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X1600 Y1600 Z500 E500 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X390 Y290 Z100 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z2 S0 ; set active high endstops
@NL61 I'm not familiar with NPN sensor but maybe there is some latency in the way they trigger? I note that your home Z uses much lower feed rate than X or Y so try reducing the feedrate for X and Y and see if that helps.
The other thing I note is that you use a feedrate of 9000 mm/sec for initial your Z axis moves which is very fast for a Z axis. I doubt that would cause a problem with XY homing but you ought to reduce that speed.
@deckingman
thanks for your answer, I reduced the speed but this was not the problem. It did not help.
@NL61 said in H-Bot Endstop problem:
did you make sure that x and y endstops are not swapped.
i.e if you trigger the endstop and check with m119 only the x is at stopped
@Veti
thank you, I tried this. If I trigger x, only x is stopped
Please very that you are running 2.04. because the commands in your homing file contain statements that would not cause a stop in previous versions.
post the output of M115
@Veti
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.04 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-11-01b1
Don't use
G1 H2 ...
moves in your home.g files. These make the motors move individually, which you don't want. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Homing_filesIan
@droftarts
Hi Ian, thanks, I tried this out already. Always the same.
My homex looks like this now:G91 ; relative positioning
G1 S2 Z5 F1800 ; lift Z relative to current position
G1 S1 X-395 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 S2 X5 F9000 ; go back a few mm
G1 S1 X-395 F360 ; move slowly to X axis endstop once more (second pass)
G1 S2 Z-5 F1800 ; lower Z again
this looks ok.
please verify that you are changing the files in the sys folder and not in the macro folder
The link to the CoreXY homing files page needs updating; better to use
G1 H#...
, notG1 S#...
, as use of the 'S' parameter for homing is deprecated (though still works in RRF2.x); see G1.You shouldn't be using H2/S2. This moves the individual motor, so the nozzle will move diagonally. Just use H1. You don't need to specify H/S on the Z moves at all, unless it's likely to be near the endstop.
What does it actually do during homing X? Step through the Gcode line by line (send each line via the console) and report what happens.
Comments in bold.
G91 ; relative positioning - this is OK
G1 S2 Z5 F1800 ; lift Z relative to current position - this is OK too but you should use H2 here for the single Z motor
G1 S1 X-395 F1800 ; move quickly to X axis endstop and stop there (first pass) - this is OK but again, use H instead of S
G1 S2 X5 F9000 ; go back a few mm - before this move, the axis has already been homed so you don't need the S2 parameter - remove it.
G1 S1 X-395 F360 ; move slowly to X axis endstop once more (second pass) - this is OK.
G1 S2 Z-5 F1800 ; lower Z again - this should be OK but use H instead of S.
G90 ; absolute positioning - this Ok
Alternatively, you could put M564 H0 at the start of the homing file and take out all the S2 or H2 parameters. Then put M564 H1 at the end.
@deckingman
I changed everything as you wrote. It still crashes into the frame.
can you execute the commands from deckingman in the console one by one manually
@Veti
I did so. After G1 H1 X-395 F1800 it crashed.
@NL61 Do you have a probe set up in config.g? Please post your whole config.g.
Here it is:
M550 P"Olli3" ; set printer nameM669 K1 ; switch to CoreXY mode
M553 P255.255.255.0
M574 X1 Y1 Z2 S0 ; set active high endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M140 H-1 ; disable heated bed
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
this is VERY strange.
if M119 says the endstop is triggered the G1 H1 command should stop when the endstop is triggered.The Firmware version is the correct one.
I agree, very strange. Typical causes of this type of problem would be:
- Endstops pulling the input low enough to light the LED, but not low enough to register as a low input to the processor. But in that case, M119 wouldn't show the endstops as triggered when you test them.
- X and Y endstop connections swapped
- Axis movement incorrect (easy to do on a CoreXY machine), for example G1 H1 X-395 is actually moving the Y axis, or is moving X away from the endstop switch.
thanks for answering,
I tried M119 serveral times for each axis, it always shows if triggered or not.
the endstops are not swapped and the movement goes to the correct direction.
One thing that keeps leaping out at me from the config.g file, is the steps per mm for X and Y but I don't see what this would have bearing on the end stop triggering. But with a 16 tooth pulley, 2mm pitch, and 0.9 degree motors, the value is around 80 so having the steps per mm set to 32 would imply something like a 50 tooth pulley which is pretty huge. 32 steps @16x micro stepping is 2 full steps per mm or 100 mm per motor revolution using 1.8 degree motors.
the endstops are not swapped and the movement goes to the correct direction.-
Can you confirm that the homex.g file looks exactly like the one you posted above when you open it in Duet Web Control?
If you try to home just X (by pressing the Home X button in Duet Web Control, or by sending G28 X), does movement stop if you trigger either the X or Y homing sensors manually?
Until you have homing working, you may wish to reduce the motor currents.
once again the homex.g file:; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v2.1.2 on Mon Nov 11 2019 14:44:06 GMT+0100 (Mitteleuropäische Normalzeit)
G1 H2 Z5 F1800 ; lift Z relative to current position
G1 X5 F1800 ; go back a few mm
G1 H2 Z-5 F1800 ; lower Z again
G90 ; absolute positioningI tried to home X and triggered both, X and Y Endstop. No reaction
Could you try swapping your NPN sensor for a microswitch, just to check it's working correctly?
@droftarts
hmm, the micro switch is working in X and Y.
The Sensors are MLM8-3002NA NPN, Schließer.
24 V and a BAT43 Diode at the signal output.
Why does the z-axis work? Its all the same setup.I have to leave now. Thank you all for your answers, if there are any ideas whalt I can di to get those sensors working, I`ll try tomorrow.
