    WiFi spontaneous disconnect
    • Ethelredundefined
      Ethelred
      Hi -
      Cannot now connect DWC via wifi. I had been running successful prints all day. Then a period of inactivity doing other PC things - the computer and the printer were not turned off during this period. When I returned to DWC I found it had disconnected. Turned everything off and re-tried without luck. The PC communicates with the other wifi devices. Tried DWC from another computer on the net and no joy. The IP address is correct. I did not interact with Duet in any way during the inactive period ( possibly about an hour ). Any suggestions as to how I can troubleshoot this problem - the board is quite new - Sept 2019 from Filastruder - and has been working flawlessly.
        When you power on the board do you see the blue LED on the wireless module turn on at all?
        Ethelredundefined 1 Reply Last reply Reply Quote 0
        • Ethelredundefined
          Ethelred @Phaedrux
          @Phaedrux Yes, blue LED light on.
          • Ethelredundefined
            Ethelred
            Situation resolved - but I have no idea what/how happened. And found this almost by a fluke.
            Normal ip address was 10.0.0.187 and was used for months and called by a bookmark ( to ensure my crappy typing would not be in play ). So, anyway, that didn't work.
            I decided to run a print by "sneaker-net" from the touch panel and somehow a notice popped up saying something like " connected blah blah to 10.0.0.188 . The ip address had ratcheted up one digit from 187 to 188.
            Everything now working fine. Can anyone explain to me how this happened?
              Your router is probably serving it a DHCP address and you haven't reserved it for the duet so it just got a new IP.
