    PT-100 temperature constantly at 2000 degrees after failure
    54
    5478
    • CoolM8
      CoolM8 last edited by
      I had the issue on the first print after finally fixing the homing config issue, that the temperature reading showed "Failure". I had to turn the printer off and on again in order to get it working again. Sadly after it failed a second time and it went into reading 2000 degrees ever since then. I'm using a PT-100 sensor and the daughter board and i even switched to the second RTD Pin but it's still reading 2000 degrees. I've even replaced the sensor with no luck.
        Does it read 2000 even with just usb power? If so then you have a bad connection, either in the wiring between the daughter board and the sensor, or the links you use for 2-wire connection are not working. Use a multimeter to check the wiring. The resistance of the sensor should should be a little over 100 ohms at room temperature.
        • gzcwnk
          gzcwnk last edited by
          The other possibility that happened to me was electrical interference from the extruder stepper. So every time I fed filamenthe PT100 went to 2000C and tripped out on safety. To solve it I ran double shielded super flex microphone cable between the duetwifi and the PT100, no issues in 3+months. PS only earth it at the duetwifi end if you do this.
          • CoolM8
            The issue still exists if only connect through USB. As this setup has worked before i don't think that there is any interference. I'm using the E3D PT-100 sensor but the strange thing is that i cannot measure any resistance not with the sensor that used to work nor with the new sensors that hasn't been used before. I have also another PT-100 sensor where i can measure its resistance to be around 100 Ohms, but the issue with the 2000 degrees still exists.
            • T3P3Tony
              When you say you cant measure any resistance, is that with the PT100 connected to the daughterboard? if so then please try with it not connected to the daughterboard. At that point if it is not ~100R then you have a issue in the sensor or the wiring.
              www.duet3d.com
              • CoolM8
                No, i cannot measure it when sensor is not connect to the daughterboard. But it seems still strange, it would mean I have two new E3D PT100 sensors that do not work? But even with the PT100 sensor from the Ultimaker Original where i can measure the resistance I sill have the same issue with the temperature reading. This would mean i have 2 issues at hand and even with the same setup that used to work before it went 2 times into failure. This is utterly strange.
                • ShadowX
                  ShadowX last edited by
                  Did you inspect the PWB board and connectors to make sure that none of the circuit traces are broken or if there is damage on the solder joint or connector?
                  • CoolM8
                    I don't see anything that any of the circuit traces are broken nor does anything look damaged.
                    With the reprapfirmwar tool i get this config for the E3D thermistor:
                    [[language]]
                    M305 P1 T100000 B4725 C7.060000e-8 R4700 X201 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 201
                    But i also tried everything else even:
                    [[language]]
                    M305 P1 X201
                      Do you have the PT100 connected to the first or second channel on the daughter board? 201 is the second channel, the first is 200.
                      • CoolM8
                        Right now i have on the second channel. As I've said, it used to work on channel 1 until the failures and since then it doesn't even work on channel 2.
                          Do you have a resistor of between 100 and 200 ohms that you can connect to the terminal block in place of the PT100?
                          • CoolM8
                            No i don't have a resistor around but i think this won't make a difference. Since the Ultimaker Original has a measurable resitance of around 100ohms. It measures like in the image below (the green connection has around 110 ohms):
                            It seems to me that the issue is with the daughter board or the duet itself.
                              Do you have anything else connected to the SPI bus, for example a ribbon cable connecting the CONN_SD port on the Duet to the PanelDue for using a second SD card?
                              If the answer is no, please ask your supplier for a new daughter board.
                              • CoolM8
                                Well, I've ordered a new daughter board but i still get the same issue. And no I've nothing connected to SPI bus. There is no PanelDue nor a second SD card.
                                  Have you removed the PT100 sensor from the hot end or is it still installed? I'm wondering whether it may have developed a short between the element and the case.
                                  • CoolM8
                                    It's the same even if installed in the hotend or not. If I read the voltage on the middle 2 pins I get a reading of about 2V with the E3D PT100 and about 0.2V for the Ultimaker PT100. With both those voltages i get 2000 degrees in the Frontend.
                                      The 0.2V with the Ultimaker sensor sounds plausible, the 2V with the E3D one sounds like an open circuit sensor, or else it's a thermistor not a PT100.
                                      If you send the M305 P1 X201 command from the Gcode Console, does it return an error message?
                                      • CoolM8
                                        It is all fine when I send M305 P1 X200 or X2001, no error message whatsoever. It even turns off the fan shortly that is set to start at 40 degrees but that runs continuously now because of the 2000 degrees.
                                          What voltage do you read across the outer 2 pins of the 4 pin terminal block? It should be the same 0.2V that you get across the inner ones, with the good PT100 connected.
                                          • CoolM8
                                            Yes the outer 2 pins show 0.2 V as well. I really don't get this, why did it used to work and now nothing helps? There is nothing burnt or damaged on the duet itself.
                                              My best guess is that the SPI bus isn't working but I'm puzzled that there is no error message. Do you have anything connected to the expansion connector?
                                              • CoolM8
                                                Still no, as I've already said.
                                                  I suggest you ask your supplier to replace the Duet.
                                                  • CoolM8
                                                    Well, I've gotten the replacement for the DuetWifi, but since i haven't seen any damage at my previous DuetWifi I haven't had big hopes and thats exaclty what it tourned out. No luck and everything is still the same, giving me a reading of 2000 degrees. I have even tried the solution from here: https://miscsolutions.wordpress.com/2016/06/25/more-delta-printer-upgrades-wifi-and-silence/.
                                                    There was also the E3D PT100 sensor used and 4 wires were connected to the sensor wires.
                                                    Now everything is new: the duet, the daughter board & the PT100, so it must be the configration. I have tried the following configs:
                                                    • M305 P1 X200 (E3D and Ultimaker PT100)
                                                    • M305 P1 T100000 B4725 C7.060000e-8 R4700 X200 (E3D PT100 only)
                                                    • M305 P1 X201 (E3D and Ultimaker PT100)
                                                    • M305 P1 T100000 B4725 C7.060000e-8 R4700 X201 (E3D PT100 only)
                                                    what else could be the issue here?
                                                    • deckingman
                                                      deckingman last edited by
                                                      Maybe it's because you've set P1 to use both channels (X200 and X201). If you've only got one PT100 and it's used on the hot end, all you need is M305 P1 X200. If you are using 2 PT100s, one for the bed and one for the hot end, then you have something like M305 P0 X200 and M305 P1 X201. You don't need the thermistor and ADC parameters for a PT 100 but those lines probably just get ignored.
