    More then 3 fans on duet Maestro?
    • MacNite
      MacNite last edited by
      Hey Guys,
      I am looking for a solution to controll more then 3 fans with my Duet Maestro. I want the following:
      • Coldend, thermally Controlled
      • Part Cooling, gcode Controlled
      • Chamber, thermally controlled
      • electronics, thermally controlled
      • LED in Heater 2
      I might use some Outputs and external mosfets for that and so on.
      I Control the LED by Just writing to Pin 2.
      But If I want to add Fans past fan2 the Firmware states that the number has to be between 0 and 2.
      Any was to avoid that.
      Thanks
      CorEssentials on GitHub | Instructables Profile | Thingiverse Profile
        dc42 administrators @MacNite last edited by dc42
        @MacNite said in More then 3 fans on duet Maestro?:
        Hey Guys,
        • LED in Heater 2
        Thanks
        Yes, use RepRapFirmware 3, which is in beta. Currently it supports up t 4 fans, but I can increase that if it helps.
          dc42 administrators @dc42 last edited by
          PS - I just increase the maximum number of fans on the Maestro to 6 for the next RRF3 build.
          • MacNite
            Thank you David!
            I think I have to Switch to RRF3 in this Case...I knew, this time would come 😛
