Doubts about correct compensation mesh configuration
Hi guys, I need your support. I have been reading everything for days but I cannot understand. I have a self-built coreXY (duet 2 wifi with firmware 2.04) with original bltouch v3. The printer prints well and the bltouch "seems" to work well (let's say the first layer is good) but I have doubts if it works or does not work the compensation mesh and I have doubts about the correct configuration of the start.gcode. My z-axis is driven by a single motor that commands two leadscrews.
Could anyone please check my configuration files and help me? Thanks to all in advance.
These are some configuration files (if you need others, ask for them):
Config.g
M569 P0 S0 ; Physical drive 0 goes backwards
M569 P1 S0 ; Physical drive 1 goes backwards
M569 P2 S1 ; Physical drive 2 goes forwards
M569 P3 S1 ; Physical drive 3 goes forwards
; M92 X80.00 Y80.00 Z800.00 E440.00 ; Set steps per mm
M92 X160.00 Y160.00 Z800.00 E440.00 ; Set steps per mm
; Speeds
M566 X900.00 Y900.00 Z60.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min) Jerk
M203 X15000.00 Y15000.00 Z300.00 E10000.00 ; Set maximum speeds (mm/min)
M201 X2000.00 Y2000.00 Z60.00 E6000.00 ; Set accelerations (mm/s^2)
M204 P4000 T2000 ; Set printing and travel accelerations
; Motor currents
M906 X1700.00 Y1700.00 Z800.00 E600.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M208 X300 Y300 Z300 S0 ; Set axis maxima
M574 X1 Y1 S0 ; Set active low and disabled endstops
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 X0 Y0 Z1 ; Set Z probe type 9 to bltouch and the dive height + speeds
G31 P25 X-26 Y0 Z1.45 ; Set Z probe trigger value, offset and trigger height
M557 X25:260 Y25:260 S78 ; Define mesh grid
; Bed Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S130 ; Set temperature limit for heater 0 to 130C
; Hotend Heaters
M305 P1 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 1
; M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M307 H1 A687.7 C209.8 D6.9 S1 ; PID HeaterBed.g
G29 ; probe the bed and enable compensationHomez.g
G91 ; relative positioning
G90 ; absolute positioning
G1 X51 Y25 F6000 ; go to first probe point
G30 ; home Z by probing the bed set to 0Homeall.g
G1 S1 X-305 Y-305 F3000 ; move quickly to X or Y endstop and stop there (first pass)
G1 S1 X-305 ; home X axis
G1 S1 Y-305 ; home Y axis
G1 X5 Y5 F6000 ; go back a few mm
G1 S1 X-305 F600 ; move slowly to X axis endstop once more (second pass)
G1 S1 Y-305 ; then move slowly to Y axis endstop
G1 X51 Y25 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bedStartGcode
G28 ; Home XY
G1 X145 Y145 ; Move Probe to middle of bed
G30 ; Do a single probe
M375 P"heightmap.csv" ; Load my custom heightmap. Otherwise use G29 S1
G28 X0 Y0 ; Home XY
while printing check with m122 if the compensation is active
Hello Veti! When printing with the M122 command I read: "Bed compensation in use: mesh, comp offset 0.000"
Mesh compensation should it be okay then?
Do you have any suggestions (even on other parameters) on some settings to change?
@luc said in Doubts about correct compensation mesh configuration:
G31 P25 X-26 Y0
is the bltouch to the left of the hotend? sometimes this can be set wrong.
your grid is very largely spaced. try S20
@Veti said in Doubts about correct compensation mesh configuration:
G31 P25 X-26 Y0
Yes, bltouch is on the left. It is a support that I personally designed.
I try! I had given more space to have 16 points ... with S20 it will do many more.
Thank you very much!
