Height Map and Leveling Issues + Head Movement
@tdm418 said in Height Map and Leveling Issues + Head Movement:
It is impossible to level with the BLTouch as it has started reporting weird values.
Sigh! If you need help with the BLtouch: I’ve counted more than 200 threads having this thing in their titles, all in all, I found more than 600 mentions…
In case you look for a reliable replacement, you might consider this design (recommended by @Veti) or this one.
My most recent height map still has the geometric pattern. It has improved from the initial one, as the bed is now recognized as being level (sort of), and the deltas are decreasing. I would post a new picture, but am getting a server parsing error whenever I try to upload the screenshot.
I can't rule out the probe being the culprit, but the irregularities seem too consistent and rhythmic to be a probe failure.
@Phaedrux , I have tried cleaning the probe. Like with rebuilding the Z axis, the motion (to my eye) seems smoother, and the height map gradually improves with every new attempt, but it is still indicative of a different problem.
@infiniteloop , you agreed initially that this was a mechanical problem. The BLTouch is only six weeks old and has given me no trouble. In fact, it was one of the add ons that really seemed to improve the print quality. It looks like you have done some research, do you think that a failing unit would cause this sawtooth pattern?
Again, thanks to everyone for their input and suggestions. -
Well as dc42 mentioned the probe height is changing when going in one direction versus the opposite direction. Thus the peaks and valleys.
You will have to determine what about your hardware is changing as the probing changes direction.
Are your belts really tight?
Yes, the belts are tight enough that they vibrate when plucked, like a guitar string. I can't replicate any unusual motion even though I have physically twisted and pulled on everything in an attempt to replicate it. This is way beyond frustrating, but hopefully it will turn into a learning experience that can be corrected and shared.
I'm going to keep after it, but would still greatly appreciate any suggestions since I'm out of ideas, for the time. -
Have you run the tests that I suggested? Pick a position to measure. Approach that position with the print head from one direction, do a bunch of repeated height measurements. Move the head to the far side and then turn around and approach the same measurement position from the other side and repeat height measurements. This should show clearly if the sawtooth surface map is generated by mechanical slop somewhere.
If the above was done on the x axis then you might repeat the same thing on the y axis just for the heck of it.
I am planning on doing this test on my printer but have not had n opportunity to try it. In theory it should be definitive.
... I did say 'theory' .... YMMV -
I'm hoping to get to that one tomorrow. Will definitely let you know the results.
Yep, indeed. A functional BLtouch will not produce such a pattern, and I can’t imagine any reason why a dysfunctional probe should change its mind every second row in such a predictable manner.
However, I am no BLtouch expert, I don’t own one (and am glad about this, because I read tons of help requests in literally hundreds of threads). Instead, I tried different probing techniques until I finally understood the simplicity and beauty of the beforementioned design idea: a pin, an optical endstop and a cheap servo for retraction - that’s it.
After this confession, back to work: In case you still can generate said “sawtooth“ pattern, try to probe a single point repeatedly (yeah, I see @jens55 had the same idea) - are the results consistent? If not, have a closer look at your BLtouch, else: welcome to the mechanical age (somehow reminds me of “Myth“).
So, if the probe is ok, could you try to reduce the travel speed between probing points to something below 200 (“T“ parameter in M558), use at least 9 repetitions („A“) and set the recovery time (“R“) to half a second? All this makes the mesh probing painfully slow, but if you get better results than before, you should reconsider the mount of the BLtouch: it might wobble.
Well keep in mind we are talking very small mounts of unwanted movement, nothing that you could see with your eyes.
Have you tried making the belts less tight? You may have too much tension causing the some parts of the gantry to deflect/deform.
@jens55 - So I tried your idea, and found nothing. I came at the same point from + and - x and y, as well as a few diagonals. In general, the measurements were with .003, with a max of .005. Great idea, unfortunately, this thing is extremely uncooperative.
@fcwilt - The belt tension makes almost no difference in the height map at all.
What I did notice, though, is that no matter what the tension, the map seems to constantly improve. That got me thinking that there is a bearing or wheel with a "flat spot" that is gradually working itself out. That would seem to be impossible, of course, to have anything grabbing with such regularity, but I can't deny that everything that I try does improve it. So I have pulled apart every moving piece of this thing (again) and am testing and lubricating them all, even though the bearings are sealed. I even lubricated the power supply, just in case.
I had the machine in Corpus Christi with me, so maybe somehow there is a trace of oxidation that I can't see that is slowly wearing off now that I'm back in a very dry climate. Not a good theory compared to all the fantastic ideas already presented, and the regularity of the pattern would seem to preclude this as well, but I'm really grasping at straws here.
Still no "smoking gun" but I'll see how it does after a few test prints.
Oh, just kidding about the power supply... -
Well there is your problem ... you SHOULD have lubed the power supply ! The electrons are getting stuck in there because of too much friction !
