OK now I have my Raspberry Pi 4
Well my Raspberry Pi 4 arrived and I would like to check it out with the Duet 3.
But I cannot find a step-by-step set of instructions.
There was an SD card that came with the Duet 3, is that for the Pi?
Any help would be most appreciated.
Thanks.
They said the included card would be loaded with the image linked, so presumably, but the wiki will have all the info if it doesnt
My Duet 3 did not come with a card.
You can tell if the card that came with yours is for the Pi as follows:
- Insert it in a windows PC.
- If windows shows a new drive labeled "boot", AND asks you to format another drive, that's the correct card for the Pi.
DO NOT format!! Just hit cancel on that request.
If for any reason you need to "build" a card for the Pi, follow the instructions at the link given above, starting with section "Duet Software Framework on Raspberry Pi". If you've never worked with Linux, just cut/paste the commands exactly as shown and they will work fine.
So really there are four steps to get it running, and a couple more to connect to it:
- Get the image
- Balena etch the image onto an SD (no need to unzip it)
- For WiFi, edit the "wpa_supplicant.conf" file on the SD card. It contains a bunch of examples. Do edit with something that leaves the file as plain text (that is, do not use wordpad or word or etc. Do use notepad or Sublime Text or notepad++ or similar)
For ether, just plug in the cable.
- SD in Pi, power it up, let it boot and join your network.
- Find the IP address of the Pi. This depends very much on your network or router, so we can't really advise you.
- SSH to the Pi as shown in the last red circle and run those two commands.
And, of course, use a browser to connect to that same IP address and you should see DWC2 screens.
Thanks much.
The SD card behaved as you said when inserted into my Windows machine.
So I then inserted into the Pi, connected a network cable and powered it up. I could tell by querying my DHCP server what was just handed an IP address, so I tried it and I got something that looked very much live DWC 2.0.4.
A new quick tests make it clear that some things must now be configured on the Pi. I guess that is where SSH comes in.
I did edit that file regards WiFi but it didn't seem to work.
I will find something that does SSH and see what I can mess up.
@fcwilt said in OK now I have my Raspberry Pi 4:
You should be able to do EVERYTHING that is "Duet-ish" via the web interface. No SSH needed for this, ever.
With one possible exception: The Duet software framework on the Pi itself. That's the very last two commands in the red circles above. And... most Pi software is set up to run those commands a 3AM (or something like that) every so often. So if it is connected to a network, and powered on, etc. it should update itself.
You can try again. It is possible that the file has been removed from the partition that is accessible to windows. If so, name it "wpa_supplicant.conf" and make it something like this:
ctrl_interface=/var/run/wpa_supplicant update_config=1 country=US network={ ssid="USDNLN02" psk="blahblah" }
Thanks for the help.
I will pull the SD card and try again.
Using PUTTY I was able to find (I think) that file but I was unable to look at it due to permissions issues.
A search suggested a tool raspi-config which did run and had an option to change WiFi settings BUT it reported some kind of error.
I really dislike command lines.
If this happens again, prefix whatever command with "sudo".
The very first time you use sudo, it will issue some warnings and ask for the 'pi' user password. After that, it just silently works.
Sudo?
Will do.
Did I mention I really dislike command lines? What century are we living in again?
Thanks.
Command lines can be a godsend. It's a very direct way of interacting with the system. It may seem a little archaic, but sometimes the old ways are still the best ways.
@Phaedrux said in OK now I have my Raspberry Pi 4:
I knew good old DOS inside and out but I've gotten spoiled.
I pulled the SD card and the initial wpa_supplicant.conf was gone.
So I created another file on the card and made sure that all was correct.
The I reinstalled the card into the Pi, applied power and I was able to connect via WiFi.
So all is good - for now.
Thanks to all.
Now to figure out what the Pi is going to be good for.
Excellent!
At first, it is pretty transparent that the pi even exists. DWC just works, etc. It is a little faster, and the WiFi is a little more reliable, than the old way. But mostly, it is just invisible.
First potential advantage: SSH to the pi and enter:
sudo journalctl -fu duetcontrolserver
Then do something with the printer. A bunch of log info will come out in real time. The logs you see can be handy when something odd is happening. The -f means "follow". The 'u duetcontrolserver' tells it which log. Ctl-C to stop following.
If you do not happen to be actively following the log at the moment something happens, you can
sudo journalctl -u duetcontrolserver
To dump the entire log. Which will just scroll by on the terminal. So you probably want to pipe it to a grep (search), or redirect it to a file, or whatever. One example:
sudo journalctl -u duetcontrolserver | grep -i warn
Will show only the lines containing "warn". The -i flag is "ignore case".
There's a ton of unix commands, I won't go any further, there's just lots and lots of ways to manipulate that log.
One other bit of trivia that may turn out to be useful someday.
On the Pi file system, directory /opt/dsf/sd/ is what the Duet 'sees' as its 'sd card'. You can manipulate any file there with full unix tools.
Also, /opt/dsf/sd/www is Linux linked to /opt/dsf/dwc2 so it is easy to have different releases or customizations of dwc and just 'point' at them to switch.
This looks like this:
pi@duet3:~ $ ls -al /opt/dsf/sd total 24 drwxr-xr-x 6 pi pi 4096 Oct 21 19:37 . drwxr-xr-x 7 pi pi 4096 Oct 21 19:15 .. drwxr-xr-x 3 pi pi 4096 Oct 28 19:46 filaments drwxr-xr-x 2 pi pi 4096 Nov 8 21:06 gcodes drwxr-xr-x 2 pi pi 4096 Nov 11 11:54 macros drwxr-xr-x 2 pi pi 4096 Nov 10 16:22 sys lrwxrwxrwx 1 pi pi 7 Oct 21 19:37 www -> ../dwc2 pi@duet3:~ $
That last little -> is the link. Too long and confusing to try to document Unix symbolic link commands here... suffice it to say that little tricks like this make it VERY flexible to manipulate releases or similar when messing with the printer. Nothing you ever have to do... that very first set of "sudo apt-get update", "sudo apt-get upgrade" will always work from Duet's own distributions... just something you might want to do when experimenting or debugging.
Thanks much. Interesting stuff.
Perhaps you know that answer to this: Could a form of M587 be implemented that would make the necessary settings in Pi, so as to keep things more "Duet" like?
@fcwilt At my time of life (approaching 67) and with a mechanical engineering background, I'm really finding it hard to learn Linux in it's various guises. That's one of the reasons why I haven't yet "pressed the switch" on my RPi. I've put Manjaro on an old laptop which I intend to use as a dedicated printer laptop. But I don't know what the hell I'm doing with it and I'm on the cusp of putting an ssd in it and installing Windows instead.
I think I'm just going to have rely on these clever people to write any add ons or plug-ins that I might want to use.............
We will implement functions through the UI (may or may not use M587) to make this easier over time. We are deliberately being cautious about thinks like networking, file permission modification etc because we don't want to introduce security flaws into the design.
@T3P3Tony said in OK now I have my Raspberry Pi 4:
Caution can be good.
As I had a bit of difficulty getting the WiFi to work I thought there should be a simpler way.
The initial changes to wpa_supplicant.conf (they couldn't just call it "WiFi Configuration" now could they) didn't seem to work.
The suggested utility "raspi-config" didn't work for WiFi either, although I was able to change the host name (another candidate for a M command).
The second attempt at creating wpa_supplicant.conf worked.
I would hardly call the whole procedure user friendly and certainly not "Duet Like".
But I certainly understand the whole thing is still a work in progress and I am not upset with where it is.
@deckingman said: At my time of life (approaching 67) and with a mechanical engineering background...
63 and a Psych major here... we can do it !
Also, if you've been a windows user all your life, there are several basic concepts in Linux that are just "close enough looking" to windows, but VERY different even one layer under the covers, to make it more frustrating than if it were more different. If that sentence parses...
I'm not sure exactly what to suggest to break through that barrier (I had a friend that really understood both 'hold my hand', and was incredibly frustrated until that happened), so I'll see if I can find a short tutorial...
Anyway, hang in there.
@Danal Actually it was me who said about approaching 67, not @fcwilt.
I also pre-date MS Windows so I understand a bit about using the command line as per DOS. And many, many years ago I taught myself to write simple programmes using BASIC in the days of the ZX81. Likewise I've bumbled about a bit with Arduino projects and before that "bit bashing" with Microchip PICs. But I've never really grasped any of it. With me it's a case of Google and YouTube to get done what I need, then I promptly forget it all. I think the thing that serves as my brain is simply full like an old HDD that needs cleaning of all the crap that's accumulated over the years - or at least it needs de-fragmenting.
@deckingman Obviously mine needs a good defrag as well, given that I crossed the user tags (now edited).
And my "too close, but actually different" applies even more to the DOS command line vs. the Unix command line.
@Danal said in OK now I have my Raspberry Pi 4:
................And my "too close, but actually different" applies even more to the DOS command line vs. the Unix command line.
Getting too far off topic so apologies to @fcwilt but I've also been trying to learn Greek for a number of years, and "close but actually different" could be applied to the Greek Alphabet. Therefore, my excuse for not understanding Unix from now on will be "It's all Greek to me".
@deckingman said in OK now I have my Raspberry Pi 4:
I actually like seeing how these discussions evolve and branch out. There is much that can be learned from unexpected sources.
I'm no stranger to the command line but it can be tricky to remember everything especially when you don't use it often so I keep some guides bookmarked.
