    Installing Duet 2 Wifi on creality cr10 s5
    • usescoastersundefined
      usescoasters
      I just recieved my Duet Wifi in the mail today and have come across one small point of confusion. Will the new control board fit inside the stock Creality control box or do I need another external enclosure to hold it? I can't see an easy way to fit it inside the standard case so that the sd card can be accessible.
      • jens55undefined
        jens55
        When I switched my cr10 s5 to a Duet I didn't even attempt to use the standard control box.
        It's much easier to forget about it.
        In fact as I moved along, more and more of the cr10 s5 ended up in a box as spare parts for some future unknown use. Unfortunately the wallet did suffer during that time 😞
          I'm not sure how close the CR10 S5 is to the ender 3 pro case, but here's what it takes to get a Duet Maestro into the Ender 3 Pro. Might give you some ideas.
          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
          There's also a lot of enclosures available on thingiverse.
            usescoasters
            Thanks for the link but unfortunately they are almost completely different cases.
            • Vetiundefined
              Veti
              since you have the duet and the cr10 s5 it should be easy to open the box and see if it fits.
