    Bed Levelilng
    607
    • gbiskiundefined
      gbiski
      I attached a screenshot of my Mesh Grid Hightmap. (Number of probe points: 25. Probe area: 576.0 cm² Maximum deviations: -0.167 / 0.460 mm. Mean error: 0.199 mm RMS error: 0.163 mm)
      I have used on CR10s with duetwifi the filafarm filabed which is fixed without use of any springs. So the room to compensate mechanically the small hight differences is minimal.
      So far I have difficulties to print without a raft. Eve a benchy in the centre of the bed.
      What you think of the bed ? Is far off ?
      thanks a lot !!
      • Vetiundefined
        Veti
        are you sure that your thermistors are configured correctly?
        if the first layer is not sticking try lowering the printhead with babystepping.
        gbiskiundefined 1 Reply Last reply Reply Quote 0
        • gbiskiundefined
          gbiski @Veti
          @Veti
          Thanks for your advise.
          I leveled again the bed and i got better prices.
          A 0.25mm deviation is acceptable ?
          With baby stepping i can now print....
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @gbiski
            @gbiski
            post a picture of the mesh map.
            also you apply the babystepping that you require to print to the z offset (be aware about adding its the opposite) so that the babystepping is not required.
            • gbiskiundefined
              gbiski @Veti
              Hi. This is the mesh of my bed. Do you think is off ?
              • gbiskiundefined
                gbiski @gbiski
                From another perspective.
                • Vetiundefined
                  Veti
                  my first thought would be to level the bed using the screws so that the corners are at the same level.
                  secound thought would be to increase the number of probing points. 16 points for a bed of your size might not be enough as it could easily hide imperfections on your bed.
                  • gbiskiundefined
                    gbiski @Veti
                    @Veti I have the filabed system so the screws are fixed....
                    • Vetiundefined
                      Veti @gbiski
                      @gbiski said in Bed Levelilng:
                      filabed
                      i am unfamiliar with that and cant find anything on google.
                      can you post a picture of the bed setup?
                      gbiskiundefined 2 Replies Last reply Reply Quote 0
                      • gbiskiundefined
                        gbiski @Veti
                        @Veti hi,
                        I will take a picture tomorrow and post it.
                        The strange think is that I complete disabled the mesh bed leveling and got better results....
                        • gbiskiundefined
                          gbiski @Veti
                          @Veti Hello, Hereby me bed setup:
                          jens55undefined 1 Reply Last reply Reply Quote 0
                          • Vetiundefined
                            Veti @gbiski
                            that could mean that you are loading the bed leveling in the wrong order.
                            i.e. a G29 S1 before a G30
                            • Vetiundefined
                              Veti
                              i take it you wanted to the rid of the springs. i did the same thing on my printer, but i uses 2 wing nuts to attach the screws to the gantry. that way i can still adjust the bed if required, but its sturdy otherwise.
                              • jens55undefined
                                jens55 @gbiski
                                Have you got a link to the manufacturer by chance ? I looked up the web site for filafarm but didn't see any upgrades for Creality printers. That looks very interesting ....
                                • gbiskiundefined
                                  gbiski @jens55
                                  @jens55
                                  https://www.filafarm.de/collections/komplettsets/products/filabase?variant=1940882849816
                                  • gbiskiundefined
                                    gbiski @Veti
                                    @Veti Do you have a picture of your setup with the wing nuts on the gantry ?
                                    In my start gcode i have G30 and then G29 S1.
                                    The think s that i managed yesterday to get the 1st layers consistent in all 4 corners (without any bed mesh leveling) but after a while a get warping (on PLA) . Even if i lower the nozzle to the closest to the bed that i can go i still get warping after several layers.....
                                    I cannot understand if it is the filaprint the issue (maybe i must take it of and install a buildtak)....
