    Error: G-Code buffer 'aux' length overflow
    446
    • Vinculumundefined
      Vinculum
      I have one machine that is giving this error all of a sudden. It happens quite a lot as you can see:
      26-11-2019 09:49:27 Error: G-Code buffer 'aux' length overflow
      26-11-2019 09:49:24 Error: G-Code buffer 'aux' length overflow
      26-11-2019 09:46:53 Error: G-Code buffer 'aux' length overflow
      26-11-2019 09:14:06 Error: G-Code buffer 'aux' length overflow
      26-11-2019 09:06:07 Error: G-Code buffer 'aux' length overflow
      I do not know if it is related but in the PanelDue on that same machine i get several messages saying "Unknown command" but that does not show in the DWC. So I think it has something to do with only the PanelDue.
      And this printer also randomly sets the hotend heater to standby mid-print resulting in a failed print.
      I have replaced the SD card but that did not help.
        droftarts administrators
        How is the PanelDue connected? If you're using the ribbon cable, this can be a source of interference. If you are not using the SD card on the PanelDue, it's better to use the 4-wire cable.
        Vinculumundefined 1 Reply Last reply Reply Quote 0
        • Vinculumundefined
          Vinculum @droftarts
          @droftarts
          I do not use the SD on the PanelDue. All files are transferred to the Duet SD with the DWC.
          The panel is connected with the 4-pin cable.
            dc42 administrators @Vinculum
            @HBM-3D said in Error: G-Code buffer 'aux' length overflow:
            Do you also get checksum error messages?
            • Vinculumundefined
              Vinculum @dc42
              @dc42 said in Error: G-Code buffer 'aux' length overflow:
              Nope. Upload is done when idle and no issues.
                My guess is that either the PanelDue or (more likely) the cable has developed a fault.
                • Vinculumundefined
                  Vinculum
                  That is for now my guess as well. I have disconnected it since yesterday and it hasn't paused but there were still errors in the console.
                  As of this morning I can't reach the printer anymore by DWC. Still printing though....
                    jay_s_uk
                    out of curiosity, do you have a password set on the printer?
                    • Vinculumundefined
                      Vinculum @jay_s_uk
                      @jay_s_uk
                      Nope.
