    Nozzle gets smashed against the bed
    Other control boards
    2.7k
    • MJCTundefined
      MJCT
      Ok, I have to admit that I’m getting a little frustrated with this REPRAP firmware and confg tool. I thought It was going to be far easier to set up a machine than Marlin... wrong! Bugs, tons of information often contradictory/based on previous releases (that I don’t know if it is still applicable to me or not), lots of hours spend reading treads of people with problems almost like mine... but not exactly!
      Fortunately this community is amazing
      Here is one more problem
      Using Cura 4.2.1 and reprap, the nozzle gets smashed against the bed when printing a test cube.
      I’m suspicious about “G31 P500 X25 Y0 Z3.2”. I’m not shore if correctly understood the meaning of “trigger height” in the config tool (using BLTOUCH 3.1). Maybe we can start there... I used the height difference between the nozzle and the probe when in rest (the nozzle sites 3.2mm below the level of my probe when it is not diploid).
      Thanks in advance!
      ; generated by RepRapFirmware Configuration Tool v2.1.3 on Thu Nov 28 2019 16:04:13 GMT+0000 (Hora padrão da Europa Ocidental)
      M550 P"AA 300x300x600" ; set printer name
      M669 K1 ; select CoreXY mode
      M551 P"AA" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes backwards
      M92 X80.00 Y80.00 Z4000.00 E96.94 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X1750 Y1750 Z1750 E1750 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X10 Y10 Z0 S1 ; set axis minima
      M208 X290 Y285 Z585 S0 ; set axis maxima
      M574 X1 Y1 S0 ; set active low and disabled endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H0.5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X25 Y0 Z3.2 ; set Z probe trigger value, offset and trigger height
      M557 X30:260 Y30:255 S30 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M143 H0 S110 ; set temperature limit for heater 0 to 110C
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 S"Extr 1" D0 H1 F0 ; define tool 0
      T0 ; select first tool
      Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt
        The trigger height is simply the Z position when the probe triggers.
        You can execute the a G30 S-1 command to show what the trigger height is, assuming the probe is working.
        MJCTundefined 1 Reply Last reply Reply Quote 0
          3.2mm seems quite high for a BLTouch. When mounted correctly as described in the BLTouch install instructions the probe body should be 8mm above the nozzle tip. This should result in a trigger height of ~2mm.
          Here is how you find your trigger height:
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
          And general instructions for the BLTouch: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe?revisionid=HEAD#Section_BLTouch
            Phaedrux Moderator @MJCT
            @MJCT said in Nozzle gets smashed against the bed:
            M558 P9 H0.5
            Your dive height is also WAY WAY too low. H0.5 is telling the firmware to only raise the nozzle by 0.5mm before trying to probe the bed. That's not going to end well. H5 for 5mm is far more reasonable to be safe. After you have things working it can be lowered slightly to reduce the amount of needed travel, but it's still going to need to be more than your trigger height. Think about it. You need to raise the probe high enough above the bed for the pin to drop down below the nozzle.
              G31 P500
              Try P25 instead. This is the trigger sensitivity.
              • MJCTundefined
                MJCT @fcwilt
                @fcwilt said in Nozzle gets smashed against the bed:
                Tried G30 S-1 before posting. It didn't worked very well, but I thought that it was due to a previous mistake, and I still believe that the problem is more upstream.
                • fcwiltundefined
                  fcwilt @MJCT
                  In what way did it not work?
                  Have you made the setting changes that others have mentioned?
                  • MJCTundefined
                    MJCT @Phaedrux
                    @Phaedrux thanks (again)
                    I will try your’s several advices tomorrow. Unfortunately I don't have the printer here right now
                    • MJCTundefined
                      MJCT @fcwilt
                      @fcwilt
                      It said that the probe didn’t touch the bed, if I’m not mistaken
                      I didn’t try the settings changes because I was commuting home. I will try it firs thing in the morning
                      • fcwiltundefined
                        fcwilt @MJCT
                        @fcwilt
                        Well the dive height setting likely caused that.
                        • MJCTundefined
                          MJCT
                          Ok, I followed yours instructions and it all worked fine. G30 S-1 gave me 0.212 0.213 0.213 Pretty consistent, right?
                          Than run a Mesh Compensation that showed -0.008 to 0.138mm. I guess I can live with that, at least for now.
                          Then I started a print. A test cube sliced on Cura 4.2.1 with REPRAP on settings.
                          The problem is that it starts to print far above from the bed. The tool position in the status show Z 0.30 which should be all right because my first layer in the slicer was 0.3mm. Then I tried the same cube with 0.2mm in the first layer. The status shows Z 0.2 but again it prints far above the bed.
                          What I’m doing wrong this time?
                          M208 X300 Y300 Z585 S0 ; set axis maxima
                          M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                          G31 P25 X25 Y0 Z0.213 ; set Z probe trigger value, offset and trigger height
                          droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          • MJCTundefined
                            MJCT
                            I now realise that Z in the machine control dashboard, should be pointing 0.03 in the first case and 0.02 in the second, not 0.3 and 0.2
                            Still need your help
                              droftarts administrators @MJCT
                              You've gone from a probe trigger height of 3.2mm to 0.213mm, which seems very close. Did you follow the guide here to set the probe offset? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                              1. Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
                              2. Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
                              3. Jog the head up by 5 to 10mm
                              4. Send command G30 S-1 to report probe offset.
                              The first two points set the nozzle at Z=0. The second two determine the probe offset.
                              • MJCTundefined
                                MJCT @droftarts
                                @droftarts
                                0.213 was the value reported by G30 S-1 command twice in three attempts. Should I cut one decimal and impute 2.13 at G31?
                                And yes, I followed the wiki guide. I always do. The problem is that the guides usually don’t help me much. In this case the guide doesn’t provide any real example, neither it states the units in which the information is provided by the G30 or the units you must input at G31.
                                That’s why I am so thankful to this community. You have been fantastic. I´m not lazy, is just that WIKI guides suck big time.
                                • fcwiltundefined
                                  fcwilt @MJCT
                                  If the reported value was 0.213 that is what you use.
                                  But that value is only valid if the Z position is correct, meaning Z=0 has the nozzle just touching the bed.
                                  • MJCTundefined
                                    MJCT
                                    Tried “G31 P25 X25 Y0 Z2.13” instead of “G31 P25 X25 Y0 Z0.213” ... no surprises, it smashed the bed again!
                                    droftartsundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                    • MJCTundefined
                                      MJCT @fcwilt
                                      @fcwilt
                                      Yes I understand that.
                                        @MJCT All units are millimetres. You can change to inches with G20, but this is supposed to be used only in gcode files, not for machine calibration.
                                        Can you check that, after homing, if you send a command like G1 X100 Y100 Z0, the nozzle is not slamming into the bed? Or that the reported position of the nozzle is sensible. If that's the case, it's a problem with the gcode file. Check you haven't set any Z offset in Cura. Post you gcode file so we can check it.
                                        • fcwiltundefined
                                          fcwilt @MJCT
                                          Is the pin dropping when you issue a G30 command? The probe has to touch the bed and retract for the motion to be halted.
                                          • MJCTundefined
                                            MJCT @droftarts
                                            @droftarts Yes I understand that we are using SI units, supposedly mm, but I not sure of anything right now
                                            @droftarts said in Nozzle gets smashed against the bed:
                                            Funny (not really), yes it did slammed into the bed. But I did everything by the book (or not). Nozzle at the centre of the bed, just barely touching the bed (paper can still slide under), sent G92 Z0, pull bed down 15mm, sent G30 S-1, changed G31, sent M999.
                                            The only thing I didn’t do is the "config-override.g " thing, because I just can’t find that file any ware
