    Electrical tools recommendations - Installing Maestro
    32
    1.6k
    • Blacksheep99undefined
      Blacksheep99
      Hi, I'm a bit green when it comes to electronics but willing to learn. I've bought a duet maestro and want to have a go at installing this in a printer where I'd previously managed to fry the control board (not a good sign i admit!).
      I'm looking to kit myself up with some tools to do the job. I don't want to spend a fortune but tools always come in handy. I have the basics like electrical screwdrivers etc but would welcome recommendations for other tools, crimpers etc.
      Thanks.
      Blacksheep99undefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti
        i have used different crimping tools but have ended up with the engineer pa-09 for contact crimping.
        and a cheap ferrule crimping tool
        you should also get a multimeter to check the crimping work for possible shorts or bad crimps
        • Nxt-1undefined
          Nxt-1
          A multimeter that does not blow up in your hands would be my 1° priority I think. I know Brymen offers a nice assortment of DMM's that do not break the bank.
          I would also recommend a crimp tool, although I would advice a ratcheting type if budged allows. Same thing for a ferrule crimping tool.
          Duet3D and delta printer enthousiast. Buildlog
          Looking for Duet3D configuration support, check out Nxt-3D
            Blacksheep99 @Blacksheep99
            Thanks.
            I have a cheap multi-meter already.
            https://www.amazon.co.uk/gp/product/B06W5G1VND/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
            I was looking at this tool.
            https://www.amazon.co.uk/gp/product/B078SQXZSQ/ref=ox_sc_act_title_1?smid=A2OVL9PI39G587&psc=1
            • Vetiundefined
              Veti
              i have one of those rachet crimp tools.
              this review captures my experience quite well.
              https://www.amazon.co.uk/gp/customer-reviews/R1DB2T9AZNJFJ1/ref=cm_cr_dp_d_rvw_ttl?ie=UTF8&ASIN=B002AVVO7K
              jens55undefined 1 Reply Last reply Reply Quote 0
              • jens55undefined
                jens55 @Veti
                Another vote for the PA-09. Unfortunately it took me a while before I realized that the cheap 'crimps everything under the sun' tools crimp nothing satisfactorily!
                • A Former User?
                  A Former User @jens55
                  @jens55 said in Electrical tools recommendations - Installing Maestro:
                  given the Engineer PA-09 actually pretty much crimps everything under the sun i'd say its relatively cheap. IWISS brand makes a similar tool even cheaper, and while I don't care for the ergonomics of it, it does work as well as the Engineer tool.
                  swiss accent guy has a comparison on his channel as well I think.
                  I'll echo Veti's comment as well, cheap ratcheting crimpers are, in my experience, more often than not just plain and simple giref. good ratcheting crimpers are great but pricey.
                    Thanks everyone so far. I will heed your advice regarding a crimp tool. Makes no sense risking the board or printer for a few quid
                    • jens55undefined
                      jens55
                      It is highly unlikely that you would be risking the board but let me tell you from experience that you would most definitely risk your hair and your sanity. Trying to find bad crimp joints is something you'd best avoid. Buy the right tool for the job (which you said you would)! You will never know the amount of frustration you have avoided with that decision !
                      • A Former User?
                        A Former User
                        PA-09 is great but for the 3D printers I belive PA-20 is better choice.
                        the PA-09 is 1.0, 1.4, 1.6 and 1.9
                        the PA-20 is 1.6, 1.9, 2.0 and 2.3
                        the pins on the duet2ethernet / duet2wifi / maestro connectors need 1.6 or 1.9 for the part that grabs wire and 2.0 for part that grabs insulation. You can crimp the insulation part with 1.9 if you have to; but it is much better to do it with 2.0, and depending on the wires, you might even wanna do it with 2.3. That's why IMO PA-20 is a much better choice than PA-09 (ideally you get both 😄 )
                          droftarts administrators
                          There's this useful page on the reprap wiki for crimping: https://reprap.org/wiki/Crimping
                          I've seen this tool recommended for ferrules (by @dc42 no less): https://www.ebay.co.uk/itm/Ferrule-Crimper-Cable-Tube-Crimping-Plier-Tool-1200X-Wire-Terminal-Connector-Set/392118937290
                          I use the HT-225D ratchet crimper, widely available on ebay etc. The nice thing one for crimps, works really well, eg: https://www.ebay.co.uk/itm/Crimping-Tool-HT-225D-Free-Economy-Delivery/123594079692
                          I prefer these to the PA-09 or PA-20, as crimping is a two-stage process with them. However, you have to be quite careful about lining up the crimp, and getting the wire in the right place with the ratchet crimpers. Once you've done a few thousand of them, though, you get it right nearly every time! (I handmade 500 wiring looms once...)
                          Don't forget a good pair of wire strippers, too!
                          • jens55undefined
                            jens55
                            I prefer the two step process as I can never get everything lined up at the same time with the single step process. Mind you, after 500 crimps (ouch) I would imagine you have it sorted. On the other hand, 6 months of no crimps and you need another 500 to get back into the swing of things 🙂
                            Engineer makes a nice wire stripper (don't know the number but it's got a green handle)
                            I would like to add that it is EXTREMELY important NOT to nick the wires because the wire will always fail (eventually) at that nick. So yes, a good stripper is a must! Even with a good stripper, I use the hole for the next size up wire (ie if it's a 24ga wire I will use the 22ga stripping hole)
                            • fcwiltundefined
                              fcwilt
                              Get a ratcheted crimper with dies for the contacts you are going to use. It will save time and produce more consistent crimps.
                              Don't skimp on your tools, get the best you can afford.
                              • sinned6915undefined
                                sinned6915
                                i will 2nd the 2 step process over the ratcheting ones.
                                If you have to skimp on funds, consider the IWISS Mini Micro Open Barrel Crimping Tool from somewhere like Amazon.
                                Its almost as nice as the true engineer brand- they did not do as nice a job on the final finishing of the tool but its done right where it counts. The usual pics don't show the milling on the backside of the tool and that is where its a bit unpolished.
                                  Blacksheep99
                                  Thanks everyone, really useful information. Interesting opinions differ a little but to be expected.
                                  • A Former User?
                                    A Former User
                                    major problem IMHO with "ratchet" crimpers (the one with dies) is that I have ~100 of them and another box full of dies for those that have replaceable dies, and there's not a single one that can do all the pins .. and if you take the wrong one, that look like they should work, you usually figure too late you messed up bunch of pins 😞 .. on top of that, 50% of those PRC made are just too imprecise ..
                                    for someone asking what tool to get, it's better to have PA-09 and PA-20 to be able to crimp 99% of the connectors .. then, if same person figures he's doing a lot of type X one can get crimpers for type X specifically, but the universality of pa-09 and pa-20 is IMO unprecedented.
                                      droftarts administrators @jens55
                                      It wasn't 500 crimps, it was 500 wiring loom sets for 3D printers! About 50 to 60 crimps per wiring loom, as some wires came pre-crimped. It was for the first RepRapPro Ormerod printers. I didn't do it alone, but did do a lot of the crimping; wire stripping and heatshrinking being the other parts. It's a bit like muscle memory doing Molex KK-type crimps now! Fortunately we got a proper wire stripping/crimping machine after the initial run.
                                      Edit: So, realistically, it's about variety and quantity of crimps you are likely to crimp. If you're doing a small amount and various sizes, I'd probably say the PA-09 and PA-20 would be the most suitable, as it covers all eventualities.
                                        dc42 administrators @A Former User
                                        @smece said in Electrical tools recommendations - Installing Maestro:
                                        ...except that for the JST VH pins on Duet 3, it has to be a PA-21.
                                        jay_s_ukundefined A Former User? 2 Replies Last reply Reply Quote 0
                                          jay_s_uk @dc42
                                          Whats the difference between the PA-20 and PA-21?
                                            PA-09 does 1, 1.4, 1.6 and 1.9mm
                                            PA-20 does 1.6, 1.9, 2.2 and 2.3mm
                                            PA-21 does 1.6, 1.9, 2.2 and 2.5mm
                                            jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
