    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.0k
    • wilrikerundefined
      wilriker
      Shutdown SBC v1.0
      A small extension to listen for a user-defined M-Code (M7722 by default) to then initiate a clean shutdown of the SBC (it simply executes poweroff - and since it's usually run as root that will work).
      It can be found at GitHub Releases page.
      Usage
      $ shutdownsbc --help
      Usage of shutdownsbc:
        -shutdownMCode int
      	  Code that will initiate shutdown of the SBC (default 7722)
        -socketPath string
      	  Path to socket (default "/var/run/duet.sock")
      Installation
      • Download
      • Rename to just shutdownsbc
      • Make executable with chmod +x shutdownsbc
      • Put it into any path in your $PATH e.g. /usr/local/bin
      • Run it as root or with sudo
      • Optional: use the shutdownsbc.service systemd unit (included in the repo) to run it at startup
      Source Code
      You can find it at https://github.com/wilriker/dsfext-shutdownsbc
      Contribution
      As always I welcome any kind of contribution here or over at GitHub. Comments, suggestions, bug reports, Pull Requests, whatsoever. Everything is appreciated.
      Manuel
      My Tool Collection
      A Former User? 1 Reply Last reply Reply Quote 2
      • wilrikerundefined
        wilriker
        Exec On MCode v2.0
        After a request on GitHub to also make the command to run configurable I have renamed the whole project to execonmcode and created a new release that will make the command configurable.
        It will also report the outcome of the command (success, error) back to DuetSoftwareFramework.
        As usual it can be found at GitHub Releases page.
        Usage
        $ ./execonmcode --help
        Usage of ./execonmcode:
          -command string
                Command to execute
          -mCode int
                Code that will initiate execution of the command (default 7722)
          -socketPath string
        Manuel
        My Tool Collection
        tooundefined 1 Reply Last reply Reply Quote 2
        • tooundefined
          too @wilriker
          @wilriker Great work, the plugin works just as it should! 👍
          We're using it to build a 'move backwards in gcode' function. However, it would be great if we could bring variables into the command string, maybe that could be solved by giving the M code S, P and Q parameters that would translate into $S, $P and $Q?
          Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
          • wilrikerundefined
            wilriker @too
            @too Thanks! I saw your GitHub issue but was a bit busy the last days. Sorry for not getting back to you sooner. Also great to hear that it is actually used by someone other than myself. 🙂
            I'll think about how to do that best.
            Manuel
            My Tool Collection
            tooundefined 1 Reply Last reply Reply Quote 0
            • tooundefined
              too @wilriker
              @wilriker Now RRF3 just needs to be working smooth with some of the more exotic features and the system would be near perfection 😁
                dc42 administrators @too
                @too said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                I expect to release RRF3 RC1 very soon.
                • tooundefined
                  too @dc42
                  @dc42 looking forward!
                  • wilrikerundefined
                    wilriker
                    Release v2.1
                    This release provides parameter substitution. Please see the below for details on how to use it.
                    It can be found at the GitHub Releases page.
                    Parameters
                    execonmcode does provide a simple mechanism for parameter substitution. It is possible to pass string parameters to the
                    selected M-Code and have them inserted in the -command. In the command string they have to be single letters prefixed by
                    the percent-sign (%) and they must not be G, M or T.
                    All parameters that do not have a corresponding value in the M-Code will be forwarded as given.
                    Example
                    Run execonmcode as
                    $ ./execonmcode -command "mycommand %F %N %D"
                    Then you can use the following M-Code syntax to replace these parameters
                    M7722 F"my first parameter" N"my second parameter"
                    this will lead to an execution of
                    mycommand "my first parameter" "my second parameter" %D
                    Note that %D was passed as is since it was not given in the M-Code.
                    Manuel
                    My Tool Collection
                    oozeBotundefined 1 Reply Last reply Reply Quote 1
                    • wilrikerundefined
                      wilriker
                      Release v2.1.1
                      This is just a bug fix release to address a bug where too many (empty) parameters where introduced in between the command and it's actual parameters. This could lead to various problems.
                      Thanks to @too for reporting this. 👍
                      Manuel
                      My Tool Collection
                      • wilrikerundefined
                        wilriker
                        Just as a short teaser: the upcoming version will allow an arbitrary amount of M-code+command pairs.
                        Manuel
                        My Tool Collection
                        • tobias_munichundefined
                          tobias_munich
                          great Job !! many thanks.
                          exactly what I looked for
                          Tobias
                          Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                          Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                          Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
                          • wilrikerundefined
                            wilriker
                            Release v3.0
                            This release adds the possibility to provide an arbitrary amount of -mCode + -command tuples. This way it is possible to have a single instance of execonmcode handle all the custom commands.
                            Note that as part of this change there is no longer a default value for -mCode.
                            Get it at GitHub Releases page.
                            EDIT: This version is built agains goduetapiclient 1.2.0 and as such will only work with DSF 1.2.2.1 and later. In case you need a version that is working with DSF <= 1.2.2.0 please tell me here. It's not a problem to provide that as well.
                            Manuel
                            My Tool Collection
                            gtj0undefined 1 Reply Last reply Reply Quote 1
                            • gtj0undefined
                              gtj0 @wilriker
                              @wilriker I can't believe I missed this whole thread! Gonna give it a try tomorrow.
                              I'm also working on something to allow the SBC to do a hardware reset and flash erase via GPIO pins for cases where the firmware is stuck and you can't get to the board. Could be a good companion to your utility.
                              • wilrikerundefined
                                wilriker @gtj0
                                @gtj0 Glad to hear about any use-cases. 🙂
                                I myself use it to run poweroff as well as activating and deactivating my webcam (starting/stopping a systemd unit).
                                Manuel
                                My Tool Collection
                                • A Former User?
                                  A Former User
                                  Tempting to try with a small I2C OLED on the Pi, but not top of the list just yet
                                  • chas2706undefined
                                    chas2706
                                    @wilriker
                                    This sounds really good. I would like to use it to activate a bash script on my system but I have attempted to install it and I cant get it to work.
                                    I followed your instructions in your first post but using execonmode V3:
                                    I downloaded execonmode and placed it into /usr/local/bin.
                                    I tried to run it using sudo ./execonmode -help (just to see if it works) but I get the error message "cant open binary".
                                    Could you instruct me where i'm going wrong.
                                    BTW I am on the latest version of RRF3 and up to date with DSF etc.
                                    Thanks in advance.
                                    • wilrikerundefined
                                      wilriker @chas2706
                                      @chas2706 If you run
                                      sudo ./execonmcode -help
                                      It will try to find the executable in the current directory you issue this command. To have your shell locate it in your $PATH remove the ./ in front of execonmcode. For -help you don't need sudo BTW.
                                      To make sure that it can find it also check if
                                      echo $PATH
                                      actually does contain /use/local/bin.
                                      Last thing: you spelled it execonmode instead of execonmcode (extra "c" after "m") above. Make sure that's only a typo here. I might rename the executable in the future to something less error-prone.
                                      Manuel
                                      My Tool Collection
                                      • chas2706undefined
                                        chas2706
                                        @wilriker
                                        Thanks for the info. I will give it another go.
                                        execonmode was just a typo error in my post lol.
                                        Thanks
                                        • chas2706undefined
                                          chas2706
                                          @wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                          ./execonmcode -help
                                          I have placed execonmcode in /usr/local/bin and typed the following in the terminal without success:
                                          pi@Duet3:~ $ cd /usr/local/bin
                                          pi@Duet3:/usr/local/bin $ ls
                                          execonmcode listen-for-shutdown.py
                                          pi@Duet3:/usr/local/bin $ ./execonmcode -help
                                          bash: ./execonmcode: Permission denied
                                          pi@Duet3:/usr/local/bin $ sudo ./execonmcode -help
                                          sudo: ./execonmcode: command not found
                                          pi@Duet3:/usr/local/bin $ execonmcode -help
                                          bash: /usr/local/bin/execonmcode: Permission denied
                                          pi@Duet3:/usr/local/bin $ sudo execonmcode -help
                                          sudo: execonmcode: command not found
                                          • wilrikerundefined
                                            wilriker @chas2706
                                            @chas2706 Have you made execonmcode executable via sudo chmod +x /usr/local/bin/execonmcode? I think that's missing from the installation instructions.
                                            Manuel
                                            My Tool Collection
