SOLVED Brand new Duet Maestro does not start/is inaccessible
I recently got a brand new Duet Maestro board from a local reseller. I wired it to my Sapphire PRO 3D printer (CoreXY) by following and adapting where necessary the Ender 3 guide (https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37?lang=en). I have hooked up a 12864 Full Graphic display.
I have no idea why but it won't boot up properly (attached is a photo
I have also looked in my router assigned IP's but it won't show up on the network (activity led seems to be blinking).Does anybody have any ideea what i'm doing wrong? I will provide any additional info promptly ...
Could it be that i recieved a broken board?Thanks in advance,
Peter
Part 2 covers populating the SD card with the necessary files and how to connect via usb to set up networking?
the duet maestro does not come with a default menu for the lcd
you will have to do that yourself or use an existing one like
https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Filesalso do you have the config line to activate the display like
M918 P1 E4 F2000000 ; configure direct-connect display
in your config?
@Veti Thank you, i copied the files
@bearer thanks, i thought it should have worked, but after i followed part 2 I realized what i had skipped
I've added a note on the LCD wiring step mentioning that configuration is detailed later.
DId you reverse the connectors like in that guide for the Ender 3?
@ixlix said in Brand new Duet Maestro does not start/is inaccessible:
That shouldn't be necessary, because the LCD is a RepRapDiscount one or a clone.
- Have you tried adjusting the contrast pot?
- See @Veti 's post about enabling the display using M918. Even without menu files, you should get a message on the display if you enable the display using M918.
Thank you, it was solved with your previous answers. I needed to enable it through M918 and copy the menu files.
