    Maestro with RRF3
    My Duet controlled machine
    • PaulHewundefined
      PaulHew
      Been looking at going to RRF3 with my Maestro. Base is an Ender3, with E3D titan.
      I thought I would use the configuration tool as it seems that would be more beneficial to me.
      I can do the tweaks for thing like thermistors and the likes but wanted to get a base config first.
      I have a BLTouch.
      Going through the configuration tool, when I get to endstops I cannot select the bltouch as a probe type.
      I did notice in the 'IO Mapping' page this;
      Does this mean if I create the config it is already expecting a bltouch to be connected to the probe input?
      Hope someone can shed some light as I would like to try RRF3
      Kind Regards,
      Paul.
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @PaulHew
        @PaulHew
        i think that the config tool does not take into account the maestro properly.
        unlike the duet wifi the maestro zprobe.mod is pwm capable.
        i have not tried rrf3 myself but my guess for the maestro would be to have this in the config
        M950 S0 C"zprobe.mod" ; create servo pin 0 for BLTouch
        M558 P9 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        you will need to manually edit config for now.
          dc42 administrators @Veti
          @Veti said in Maestro with RRF3:
          That's all correct. We'll change configtool to allow zprobe.mod as the PWM control pin. @PaulHew , thanks for reporting this.
