    Best way determining correct pressure advance?
    559
    • Murloc992undefined
      Murloc992
      Hi again.. 🙂
      I was wondering, what is correct way of determining the correct value of pressure advance?
      With 0 pressure advance I get corners so bad, I haven't ever seen them that bad on a 3D printer, so I figured I will need to use Pressure Advance.
      This is a simple test cube I printed:
      first 5mm is 0 pressure advance, later 5mm are 0.0825 pressure advance. It looks MUCH better, but how would one determine correct value? I used modified marlin code and one python script I found here, but don't know much about it.
      I have a converted Prusa MK2.5 bear running a Bear extruder (bondtech).
      Is it per filament?
      Maybe somebody has better expertise and can explain it better? 🙂
      "Prusa Bear" : Full Bear frame, Bear X-Axis and Extruder. Duet 2 WiFi with RRF 3.2.2.
      • Vetiundefined
        Veti
        see
        https://forum.duet3d.com/topic/6698/pressure-advance-calibration/2?_=1576178880585
        Murloc992undefined 1 Reply Last reply Reply Quote 0
          Murloc992 @Veti
          @Veti
          I tried this, seemed to be very unintuitive.. 😕 This is where "around 0.0825" comes from..
          • Vetiundefined
            Veti
            also other factor like jerk and acceleration play into this. (also for the extruder)
            why does looking at the test print to determine the best value seem unintuitive to you?
              Murloc992 @Veti
              @Veti
              I'm almost blind.. 😅
              I feel around my prints with my nails most of the time.. 🙂
              • botundefined
                bot
                IMO, the best way is to look at, from the top, the outer perimeters of a sharp corner.
                Without PA, or too low of PA, the extrusion width will grow on the side of the corner that the nozzle is coming from, and the side of the corner that the nozzle accelerates away from will display thinner extrusion width than normal.
                With too much PA, the opposite will happen: the side of the corner that the nozzle is coming from will now be too little, and the side of the corner that the nozzle accelerates away from will be too thick.
                You have found a good value when you can not tell the difference between the two sides of the corner.
                *not actually a robot
                  Murloc992 @bot
                  @bot
                  Is this value filament specific?
                  botundefined 1 Reply Last reply Reply Quote 0
                  • botundefined
                    bot @Murloc992
                    @Murloc992 I would assume so. Probably, at least, for different types of plastic. Similar PLA might use the same value, though. TBH, I've only tested PA with PLA and only in certain circumstances.
                    • Vetiundefined
                      Veti
                      the blob at the top left could also be an indicator for 2 things.
                      -you are printing at a temperature that is to hot, causing the extruder to leak.
                      -your extrusion factor is to high, which results results in more material in some areas because of pressure buildup.
                        Murloc992 @Veti
                        @Veti
                        This is just PETG. It always does this blob at the end of the print for me..
                          Murloc992
                          I think I might have found the value that fits. 0.07 to 0.08, does this look like a normal value? I just printed a 50mm tall two perimeter cube without any auto-cooling slow downs and tracked how the corner bulges shrinked. At 0.07 they just seemed to disappear instantly. Weird.. After 0.08 the corners started shrinking very much.
                          • Vetiundefined
                            Veti
                            @Murloc992 said in Best way determining correct pressure advance?:
                            it really depends on your individual setup. there is no general value that works on every printer.
                            if you are happy with the quality, then thats the right value for your printer.
                            quote from dr cox:
                            It’s regular-strength Tylenol! Here’s what’cha do: Get her to open her mouth, take a handful, and throw it at her. Whatever sticks, that’s the correct dosage.
