Solved PT100 daughter board
I ordered a duet wifi with a smart effector with PT100. Question is: do I need a PT100 daughter board?
If not how I can connect the effector to duet?Thank you
Gabi -
Yes you will need the daughterboard to connect the PT100 to the Duet.
https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer
@Phaedrux
Thanks. Ordered one just now. -
@Phaedrux
By any chance do you know what kind of heights the board will have with the PT100 on top. The reason I ask this is I have concerns about this will fit in the space under the the bed on an Anycubic Kossel linear plus.
On the other hand if you have any other suggestion where I should mount the boards I am all earsThank you
Gabi -
@gabi68 said in PT100 daughter board:
@Phaedrux
GabiI just measured one and from the main board PCB to the highest point of the PT100 board which is the top of the terminal blocks, is 21.1mm.
@deckingman
Thank you
