Mesh bed leveling issues with IR Sensor
  • Hi
    I upgraded my cartesian printer (Ultimaker clone) from a capacitive sensor to IR sensor directly plugged into my Duet 2 Ethernet running Firmware 2.04.
    No issues setting up the sensor, nor calibrating it.
    But making a mesh bed leveling (G29) on a 25 points square surface (250 mm) always leads to a tilted bed from the front to the rear with a deviation of 1 mm or so from the front edge to the rear edge.
    I've done a careful manual bed leveling with the bed and nozzle at normal working temperature, on a clean glass plate with no coating over a black matte cardboard.
    So I am sure the bed is perfectly leveled against the gantry, but the probing gives a different view.
    The printhead is guided by 2 LM6UU on each axis which are in good conditions, so no tilt suspected.
    Has it something to do with temperature ?
    My previous capacitive sensor was having a bias with temperature and derives over the probing.
    Thanks for the feedbacks
    The IR sensor is not temperature-sensitive. The height map looks quite flat, so i think the bed surface is OK for the sensor.
    Can you provide some photos of your printer, so that I can see how the Y axis moves?
    In what direction and by how much is the sensor offset fro the nozzle?
  • Did you do the levelling following this guide?
    https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
    If you run it a few times, are the numbers converging?
  • @gtj0 said in Mesh bed leveling issues with IR Sensor:
    Sorry for the late reply
    I don't use the leveling assistant.
    I level my bed the old way, moving the nozzle close to the 3 adjusting screws, using a sheet of paper to fine tune.
    Doing the tuning twice is generally sufficient to have a good leveling.
    I will set up the manual assistant in the near future, at it will save me some time.
  • Sorry for the late reply, busy period till the holidays break.
    @dc42 said in Mesh bed leveling issues with IR Sensor:
    Yes the measurements are pretty repeatable.
    My printer is a Mankati Full-scale XT Plus, really a Ultimaker 2 clone.
    Y axis is mounted on two linear ball bearings (LM6UU japanese industrial grade), side by side, on a 6 mm rod.
    So bearing is on a 38 mm length, minimizing the tilt of the printhead.
    Same on X axis.
    The offset from the left nozzle is X + 41,2 Y + 11,25. Zero been on the nozzle tip.
    Only the rear of the printhead has sufficient room in order to keep the build volume.
