    Large Core Homing issue
    • mpolyundefined
      mpoly
      Hello, I have this little issue.
      I have set the homez.g and homeall.g files, for the head to probe the center of the bed for z homing (x250, y250).
      It never does, it just goes to x250 y0 and probes there.
      Can you please check and let me know what I have done wrong? That also affects the bed compensation i think, its never correct.
      I have the files here for your consideration, thank you for all the help.
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.3 on Tue Dec 10 2019 00:14:51 GMT+0200 (Eastern European Standard Time)
      G91 ; relative positioning
      G1 H2 Z5 F12000 ; lift Z relative to current position
      G1 H1 X-520 Y-520 F4800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-520 ; home X axis
      G1 H1 Y-520 ; home Y axis
      G1 X5 Y5 F12000 ; go back a few mm
      G1 H1 X-520 F480 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-520 ; then move slowly to Y axis endstop
      G90 ; absolute positioning
      G1 H2 X250 Y250 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G1 S2 Z5 F200 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-520 F4800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y5 F12000 ; go back a few mm
      G1 H1 Y-520 F480 ; move slowly to Y axis endstop once more (second pass)
      G1 H2 Z-5 F12000 ; lower Z again
      M550 P"GIANTCORE" ; set printer name
      M667 S1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes forwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X1 Y0 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E100.65:100.65 ; set steps per mm
      M566 X1500.00 Y1500.00 Z800.00 E10000.00:10000.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X48000.00 Y48000.00 Z3200.00 E18000.00:10000.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z500.00 E10000.00:10000.00 ; set accelerations (mm/s^2)
      M204 P500 T4000
      M906 X1900 Y1900 Z2000 E1800:1800 I20 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-16 Y-37 Z0 S1 ; set axis minima
      M208 X507 Y477 Z517 ; set axis maxima
      M574 X1 Y1 S0 ; set active low and disabled endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H3 F240 T8000 X0 Y0 Z1 ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-46 Y-4.6 Z1.21 ; set Z probe trigger value, offset and trigger height
      M557 X20:460 Y50:425 S30 ; define mesh grid
      M140 H-1 ; disable heated bed
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M307 H1 A250.9 C92.9 D10.4 V24 B0 S1 ; PID tuning parameters (gain, tc, dt, volt.PWm)
      ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0 I0 F500 H-1
      M563 P0 S"E1" D0 H1 F0 ; define tool 0
      M563 P1 S"E2" D1 H1 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M911 S23.5 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      T0 ; select first tool
        droftarts administrators
        What firmware version are you actually running? Send M115 and post the response.
        Your homeall.g looks very similar to that created by the configuration tool. However, I'm not sure that this move needs to be an H2 move:
        Try removing the H2.
        Also, can your X and Y axis really do 48000mm/min (800mm/sec)?!
        • deckingmanundefined
          deckingman @droftarts
          @droftarts That's correct. On a CoreXY, an H2 move will normally only use one motor so H2 Xnn Ynn might do strange things. Once homed, any G1 move within axis limits should work so I agree that removing the H2 parameter ought to fix it.
            droftarts administrators @deckingman
            @deckingman looks like the configuration tool is wrong, then. I’ll report it to @chrishamm.
            deckingmanundefined Vetiundefined 2 Replies Last reply Reply Quote 0
              @droftarts Not sure but I think G1 H2 Xnn will give +X +Y and G1 H2 Ynn will give +X -Y. So G1 H2 Xnn Ynn will give (+X+Y)+(+X-Y) = +X only (the +Y and -Y cancel each other out). Not 100% sure but I think that's what happens.
              • Vetiundefined
                Veti @droftarts
                @droftarts
                it was reported and fixed
                https://github.com/chrishamm/configtool/issues/18
                b0ssman created this issue in chrishamm/configtool
                closed Incorrect Homing Scripts for CoreXY and Delta #18
                  droftarts administrators @Veti
                  @Veti said in Large Core Homing issue:
                  @droftarts
                  Different issue. Tested on current RRF configuration tool 2.1.4, it puts in:
                  G1 H2 X15 Y15 F6000     ; go to first bed probe point and home Z
                  Reported here: https://github.com/chrishamm/configtool/issues/19
                  droftarts created this issue in chrishamm/configtool
                  closed Incorrect homing scripts: H2 X and Y move #19
