    Electronics cooling fan
    • boelle
      boelle last edited by
      Hi
      I tried to search a bit for my question but came up empty
      Would it be possible to only run the fans when either heaters are active or when steppers are enabled plus 3 mins after they go off?
      Or is that what popint 20 in the wishlist is about? https://www.duet3d.com/forum/thread.php?id=961&p=1
        You could control the electronics cooling fan thermostatically based on the hot end temperature. That should have approximately the effect you want.
        • T3P3Tony
          This blog post by deckingman is well worth a read:
          https://somei3deas.wordpress.com/2017/04/18/stepper-motor-and-electronics-cooling/
          uses a spare temperature channel to monitor the electronics and then thermostatically control a fan.
          Duet Hardware Designer
          www.duet3d.com
          • boelle
            nice link
            i would glue the thermistor to the underside thou as it would be hotter than the top of the chip
            has there ever been made FLIR pictures of the duet in action?
            • T3P3Tony
              Latest thermal testing
              http://blog.think3dprint3d.com/2017/04/duetwifi-updated-thermal-testing.html
              www.duet3d.com
              • deckingman
                deckingman last edited by
                @boelle:
                nice link
                I stuck it to the top because when the fan comes on, I blow cold air on the underside. If the thermistor were stuck to the underside, it would sense that cold air and turn the fan off prematurely.
