    Z offset is .030 too high after starting print?
    677
    • TheBasedDogeundefined
      TheBasedDoge
      I am having a strange issue where the Z is starting .030 higher than it should after starting a print. I have looked through my start GCODE and my config, and I can't see where this would be coming from... does anyone have any ideas on where to look?
      Start GCODE:
      G1 Z5 F15000 ;Move the platform down 5mm
      G28 ;Home
      ;Prime the extruder
      G92 E0
      G1 F200 E3
      G92 E0
      Config:
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Tue Dec 17 2019 00:47:57 GMT-0500 (Eastern Standard Time)
      M550 P"Hypercube" ; set printer name
      ;M564 H0 ;allow movement before homing
      M667 S1 ; select CoreXY mode
      M550 Phypercube ; Set machine name
      M552 S1; Enable network
      M552 S1; P0
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; enable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E80.00:80.00 ; set steps per mm
      M566 X1500 Y1500 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X10000 Y10000 Z180 E1200:1200 ; Set maximum speeds (mm/min)
      M201 X4000 Y4000 Z250 E2000:2000 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z300 S0 ; set axis maxima
      M574 X0 Y0 Z0 S0 ; set active high endstops
      ;M574 Z1 S2 ; set endstops controlled by probe
      ;M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      ;M558 P9 H5 F500 T4000 X0 Y0 Z1 ; set Z probe type to bltouch and the dive height + speeds
      ;M558 P9 H5 F100 T2000
      ;G31 P25 X20 Y5 Z.8 ; set Z probe trigger value, offset and trigger height
      ;M557 X15:290 Y15:290 S40 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 2
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0.5 I0 F500 H1:2 T100 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X-18.1 Y.4 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      • Vetiundefined
        Veti
        you can define a z offset using M206
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M206_Offset_axes
        if you dont have a probe.
        however i would highly recommend a probe unless your bed is perfectly flat
        also your thermistor settings are wrong B4138 is the default, and wrong for your thermistors.
          TheBasedDoge
          Thanks, I didn't realize the thermistors were wrong, I will fix that.
          I was trying to set up a BLTouch earlier but I had so many issues with it... So I gave up and went back to the endstop setup.
          I ran M206 and it came back with Axis offsets: X0.00 Y0.00 Z0.00
          I guess I can just set -.030? still not sure where it's getting that offset from.
            TheBasedDoge
            I just tried M206 X0 Y0 Z-0.030 and then started a print, the offset is still +.030... any other ideas? I'm stumped.
            • Vetiundefined
              Veti
              @TheBasedDoge said in Z offset is .030 too high after starting print?:
              i think you will need to allow negative movement.
              try
              M208 X0 Y0 Z-1 S1 ; set axis minima
              what was your problem with the bltouch?
              TheBasedDogeundefined 1 Reply Last reply Reply Quote 0
                What do you have in homeall?
                If you're not using a probe, how are you homing the Z axis?
                  TheBasedDoge @Veti
                  @Veti
                  Ok thanks, i'll try this after the current print finishes.
                  The BLTouch wasn't reliably deploying and retracting.... I had two times where it woudn't deploy and the bed smacked into the hotend and cracked the glass 😞
                  Then I had an issue where the probe fell out of the housing, i took it apart and saw that it was just held up by a piece of heat-shrink or something. I don't know if i have a defective one or an old one or something but it's just giving me too many issues.
                  @Phaedrux
                  here is my homeall.g. All the BLTouch stuff is commented out now. I went back to just a regular endstop
                  ; homeall.g
                  ; called to home all axes
                  ; generated by RepRapFirmware Configuration Tool v2.1.4 on Tue Dec 17 2019 00:47:58 GMT-0500 (Eastern Standard Time)
                  ;G91 ; relative positioning
                  ;G1 H2 Z2 F7200 ; lift Z relative to current position
                  ;G1 H1 X-305 Y-305 F3300 ; move quickly to X or Y endstop and stop there (first pass)
                  ;G1 H1 X-305 ; home X axis
                  ;G1 H1 Y-305 ; home Y axis
                  ;G1 X10 Y10 F7200 ; go back a few mm
                  ;G1 H1 X-305 F300 ; move slowly to X axis endstop once more (second pass)
                  ;G1 H1 Y-305 ; then move slowly to Y axis endstop
                  ;G90 ; absolute positioning
                  ;G1 H2 X-5 Y10 F7200 ; go to first bed probe point and home Z
                  ;G30 ; home Z by probing the bed
                  G1 H2 Z5 F9000 ; lift Z relative to current position
                  G1 H1 X-305 Y-305 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H2 X5 Y5 F9000 ; go back a few mm
                  G1 H1 X-305 Y-305 F300 ; move slowly to X and Y axis endstops once more (second pass)
                  G1 H1 Z-305 F300 ; move Z down stopping at the endstop
                  G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                  G1 S2 Z2 F120 ; lift Z relative to current position
                    Phaedrux Moderator @TheBasedDoge
                    @Veti said in Z offset is .030 too high after starting print?:
                    try
                    Note that if you do this with an endstop, the homing move on the Z axis will set the position to -1 since that's what the minima is set to.
                    In your homeall you have a G92 after the Z axis homing move to reset the position to whatever you want. Currently 0. So if the resulting position isn't accurate, you can adjust this G92.
                    However, this assumes your bed is level and perfectly flat.
                    How are you measuring 0.03 anyway?
                    It sounds like your BLTouch was faulty. Was it a clone? What version?
                      TheBasedDoge
                      @Phaedrux When I homeall, the offset shows 0. Once I start the print it says Z is .030 under head position on the Machine Status screen, and then it starts printing in the air above the bed. It's really weird.
                      Not sure what version my BLTouch is... I bought it over a year ago and only tried putting it on now. Maybe i should get a brand new one and try again? The housing says 3DTouch on it, but the PCB says BlTouch. no idea of it's a clone.
                      • Vetiundefined
                        Veti
                        3DTouch
                        that is a clone. they tend to be unreliable.
                        what layer height have you specified in your slicer.
                        the first print starts at the layer height that you specified. it never starts at 0 because there would be no space for the plastic to go.
                          3DTouch
                          It's a clone. Get a genuine Antclabs BLTouch V3.1.
                          There are other good probe options. The DC42 IR probe is really good as well. The print surface will need to work with the IR sensor though.
                            TheBasedDoge
                            Ok, I guess i'll order another real BLTouch. Im using PEI over glass so I dunno if an IR probe will work
                            In the mean time i still need to figure out the weird offset issue. My layer height is .2 right now, using Cura to slice.
                              Can you post the first 50 lines or so of your sliced gcode file?
                              Do you have an offset configured in cura?
                              Are you able to use the baby stepping function in the web control to adjust your first layer to print properly?
                              Have you calibrated the extruder so that you're getting the right amount of extrusion?
                                TheBasedDoge
                                No offset configured in cura.
                                I can use the baby stepping to fix it but I have to click it a ton of times... I've just been manually turning the z motor to adjust the offset.
                                Here is the GCODE:
                                ;FLAVOR:Marlin
                                ;TIME:10883
                                ;Filament used: 5.77495m
                                ;Layer height: 0.1
                                ;MINX:117.122
                                ;MINY:126.967
                                ;MINZ:0.3
                                ;MAXX:183.437
                                ;MAXY:171.213
                                ;MAXZ:74.4
                                ;Generated with Cura_SteamEngine 4.4.0
                                M140 S60
                                M105
                                M190 S60
                                M104 S225
                                M105
                                M109 S225
                                M82 ;absolute extrusion mode
                                G28 ;Home
                                ;Prime the extruder
                                G92 E0
                                G1 F200 E3
                                G92 E0
                                G92 E0
                                G92 E0
                                G1 F1500 E-6.5
                                ;LAYER_COUNT:742
                                ;LAYER:0
                                M107
                                G0 F2215.4 X118.845 Y138.206 Z0.3
                                ;TYPE:SKIRT
                                G1 F1500 E0
                                G1 F1200 X119.46 Y137.693 E0.03996
                                G1 X119.512 Y137.65 E0.04332
                                G1 X120.337 Y136.988 E0.09609
                                G1 X121.752 Y135.797 E0.18837
                                G1 X122.38 Y135.373 E0.22617
                                G1 X122.98 Y135.054 E0.26007
                                G1 X123.046 Y135.02 E0.26378
                                G1 X124.288 Y134.392 E0.33321
                                G1 X126.703 Y133.084 E0.47023
                                G1 X129.059 Y131.72 E0.60605
                                G1 X130.064 Y131.104 E0.66486
                                G1 X130.114 Y131.074 E0.66777
                                G1 X130.708 Y130.723 E0.70219
                                G1 X130.795 Y130.673 E0.7072
                                G1 X131.073 Y130.519 E0.72305
                                G1 X131.446 Y130.339 E0.74372
                                G1 X131.917 Y130.145 E0.76913
                                G1 X132.007 Y130.11 E0.77395
                                G1 X132.443 Y129.944 E0.79722
                                G1 X132.726 Y129.849 E0.81212
                                Vetiundefined 1 Reply Last reply Reply Quote 0
                                  Can you try updating to the latest 2.05 firmware release?
                                    TheBasedDoge
                                    I did that yesterday actually, no change
                                    • Vetiundefined
                                      Veti @TheBasedDoge
                                      are you sure the web gui is report 0.03 and not 0.3 ?
                                        TheBasedDoge
                                        Yes ^
                                        Ok, so I tried PrusaSlic3r and it's not doing it? Where in Cura would be causing this weird issue?
                                          Can you save a .3mf file from cura and post it somewhere to share it here?
                                            TheBasedDoge
                                            sure, try this
                                            https://www.dropbox.com/s/wnt6123go95dghe/test.3mf?dl=0
