    Z probe already triggered at start of probing move
    • BearcatTDundefined
      BearcatTD
      I just installed a Titan Aero on my Ender 3 and I am doing a bit of testing. Everything seems to be working fine other than I get a "Z probe already triggered at start of probing move". I unplugged the cable from the BLTouch when I installed it on the new mount and it is seated about as firmly as it can be. I never unplugged any of the BLT cables from the Duet 2 wifi. X and Y homes great.
      As always, I very much appreciate the help!
      Pat
      retractprobe.g
      homez.g
      homey.g
      homex.g
      homeall.g
      deployprobe.g
      config.g
      Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
      Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
      • Vetiundefined
        Veti
        @BearcatTD said in Z probe already triggered at start of probing move:
        this indicates faulty wiring. even with the pin up this should not happen on a bltouch.
        check each wire for their correct placement,
          BearcatTD
          Right. Currently, the pins are connected based on the guide:
          https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
          I think I might just put on new connectors just for kicks to see what happens
          Thanks!
            BearcatTD
            White wire needed repair! Thanks.
            Follow up question inbound!
