Duet 2 wifi corexy homing z in middle of the bed issue
Hi...I just setup my custom corexy with a duet 2 wifi board and a precision piezo orion v2 in digital mode as a bed probe...for x and y I use optical endstop at 0,0 position,so far so good...I can home individual axis and all work ok...but I want to home z axis in middle of the bed and it seams that I cannot achieve this...I edited the homez.g and homeall.g for the nozzle to go to x150 y150 but only it's only go to x150 then home z axis...my working area is 300x300x315
post your config and homing files.
G1 H2 X150 Y150 F9000 ; go to first bed probe point and home Z
H2 moves are not for Corexy. delete H2
That is a new configuration file made today on reprap configuration tool...why it put the h2 in homez.g and homeall.g?
Ok...sweet...thank you so much.. I've deleted the h2 from homez.g and homeall.g
All work as it should.. thank you... -
@weed2all said in Duet 2 wifi corexy homing z in middle of the bed issue:
Known issue. Will be resolved in next update.
