G29 on delta below bed
  • Hi,
    I've been round and round web pages trying to figure out what to do. AC Predator Delta with Duet WiFi installed. I've managed most of the config, but really struggled with G32 and z=0 etc. Just managed it, but now the G29 always gives weird results way below the bed. Any suggestions? bed1.JPG
    Please post your config.g and bed.g files.
    Your height map looks odd, because for a delta it would normally be circular with the origin at the centre.
  • Hi, Thanks for having a look. I commented out all loading of the height map as I was having a lot of problems with it.
    CONFIG.G
    ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
    G21 ; Work in millimetres
    M552 S1 ; connect to WiFi
    ; Delta Settings
    M665 L440 R227 H456.747 B185.0 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
    ;M665 L440.000:440.000:440.000 R227.123 H456.747 B185.0 X-0.079 Y0.344 Z0.000
    ;M666 X2.302 Y-1.669 Z-0.633 A0.00 B0.00
    ;M98 P"homedelta.g"
    M550 P"Anycubic Predator2" ; Set machine name
    M551 P"" ; Set password
    ;M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P3 S1 ; Drive 3 goes forwards HOT END
    M92 X160.00 Y160.00 Z160.00 E835 ; Set steps per mm
    M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min)
    M203 X12000.00 Y12000.00 Z12000.00 E10000 ; Set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z3000.00 E3000.00 ; Set accelerations (mm/s^2)
    M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    ; Retraction
    M207 S4.0 F5000 R-0.025 T2500 Z0.5 ; Firmware retraction
    M208 Z0 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S1 ; Set active high endstops
    M558 P4 H5 F120 T6000 ; Set Z probe type to switch(P4) and the dive height + speeds
    G31 P500 X0 Y0 Z17.639 ; Set Z probe trigger value, offset and trigger height
    M557 R115 S20
    ;*******************G29 S1 ; Load the heightmap
    M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
    M305 P0 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 1
    M143 H1 S240 ; Set temperature limit for heater 1 to 240C
    ; Tools for p0
    M563 P0 D0 H1 ; Define tool 0
    M572 D0 S0.1 ; Pressure Advance
    ;M591 D0 P2 C4 S1 ; Activate filament sensor
    M404 N1.75 ; Set for print monitor
    M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0
    T0 ;select tool 0 gary added
    CONFIG-OVERRIDE.G
    ; config-override.g file generated in response to M500 at 2019-12-29 11:02
    ; Delta parameters
    M665 L440.000:440.000:440.000 R227.575 H457.035 B185.0 X0.240 Y0.449 Z0.000
    M666 X2.670 Y-1.750 Z-0.921 A0.00 B0.00
    ; Heater model parameters
    M307 H0 A137.8 C533.3 D1.5 S1.00 V24.3 B0
    M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
    M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
    M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
    M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
    M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
    M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
    M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
    G10 L2 P1 X0.00 Y0.00 Z0.00
    G10 L2 P2 X0.00 Y0.00 Z0.00
    G10 L2 P3 X0.00 Y0.00 Z0.00
    G10 L2 P4 X0.00 Y0.00 Z0.00
    G10 L2 P5 X0.00 Y0.00 Z0.00
    G10 L2 P6 X0.00 Y0.00 Z0.00
    G10 L2 P7 X0.00 Y0.00 Z0.00
    G10 L2 P8 X0.00 Y0.00 Z0.00
    G10 L2 P9 X0.00 Y0.00 Z0.00
    BED.G
    ; bed.g
    ; called to perform automatic delta calibration via G32
    ; generated by RepRapFirmware Configuration Tool v2 on Mon Apr 08 2019 07:52:58 GMT+0100 (British Summer Time)
    G28 ; home all towers
    ; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
    ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
    G30 P0 X0.00 Y80.00 Z-99999 H0
    G30 P1 X51.42 Y61.28 Z-99999 H0
    G30 P2 X78.78 Y13.89 Z-99999 H0
    G30 P3 X69.28 Y-40.00 Z-99999 H0
    G30 P4 X27.36 Y-75.18 Z-99999 H0
    G30 P5 X-27.36 Y-75.18 Z-99999 H0
    G30 P6 X-69.28 Y-40.00 Z-99999 H0
    G30 P7 X-78.78 Y13.89 Z-99999 H0
    G30 P8 X-51.42 Y61.28 Z-99999 H0
    G30 P9 X0.00 Y40.00 Z-99999 H0
    G30 P10 X34.64 Y20.00 Z-99999 H0
    G30 P11 X34.64 Y-20.00 Z-99999 H0
    G30 P12 X0.00 Y-40.00 Z-99999 H0
    G30 P13 X-34.64 Y-20.00 Z-99999 H0
    G30 P14 X-34.64 Y20.00 Z-99999 H0
    G30 P15 X0 Y0 Z-99999 S6
    ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
    ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
    ;G29
    Thanks
    Gary
  • @Gary said in G29 on delta below bed:
    try S7 to see if the rod length is correct.
    then try S8 calibration to see of you have a significant tilt.
  • Thanks will check out S7. I've put level on it and there's no significant tilt, but again I'll check it out.
  • I think dc42 is correct and there's something wrong with the delta "model" in my code. I was thinking of upgrading my other delta to Duet, but it does not seem as easy as it sounds.
  • from
    https://forum.duet3d.com/topic/10724/autocalibration-problems-anycubic-predator-duet-wifi-2/2?_=1577642698773
    ; Delta configuration
    M665 R227 L440 B185 H455 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
  • @Gary I have a predator running a duet if you still need a hand. Send me a PM if you do
  • Problem solved! This has taken months. I checked grub screws, belt teeth…. I had noticed that now and then the hot end juddered when moving to position, but not all the time. The person I bought the machine from had cable tied the hot end cable harness to 1 of the Z motor arms. It was hanging loose and tidied up the harness, as it does tend to flop about on my other machine.
    When close to the bed (within 10mm) and only in specific positions it held the arm causing the belt to slip! Also G29 failed most of the time as the probe was not triggered due to the arm being held back. The judder now solved, G29 completes and bed leveling showing a decent graph.
    Thanks for your help. (I have learned lots of G code and Duet wiring though)
    Gary
