    M581 in RRF3 not triggering trigger2.g
    1.1k
    • chas2706undefined
      chas2706
      I have created a trigger in my config.g as follows:
      M581 P"!io2.in"T2 C0 ; configure active-low endstop to run a macro called trigger2.g
      The file trigger2.g in config.g has the following code:
      G91 ; relative positioning
      G90 ; back to absolute positioning
      The input is connected to a microswitch. When I operate the switch the code does not run.
      If I do a M98 P"trigger2.g" in the console, the code runs.
      If I change T2 in the M581 parameters to T0, the trigger works and sends an emergency stop. Anyone have any ideas why M581 P"!io2.in"T2 C0 does not trigger the trigger2.g macro?
      deckingmanundefined A Former User? 2 Replies Last reply Reply Quote 0
      • deckingmanundefined
        deckingman @chas2706
        @chas2706 How have you wired it? Edit. I mean which pins have you used.
        • tekkydaveundefined
          tekkydave
          You may need to enable the pull-up by adding a '^' to the P parameter
          M581 P"^!io2.in" T2 C0
          Also there is no space between the P and T params - not sure if relevant or not.
          ~ tekkydave ~
          D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
          FreeCAD, PrusaSlicer
          • A Former User?
            A Former User @chas2706
            @chas2706 said in M581 in RRF3 not triggering trigger2.g:
            does not compute. which folder is trigger2.g in?
            @tekkydave said in M581 in RRF3 not triggering trigger2.g:
            very much so, good catch! i believe lack of space is okay while additional space is not when the parser is reading the g-code. i.e. X0Y0 is equivalent to X0 Y0 but not necessarily the other way around (could be wrong again)
            • chas2706undefined
              chas2706
              @deckingman
              Hi it is wired to io2.in which are the general io pins on duet3.
              If I configure io.2 as an end stop, it works so therefore proves the wiring is ok.
              • chas2706undefined
                chas2706
                @bearer
                I have put trigger2.g in the /sys folder as per documentation.
                I have tried with and without spaces between P and T parameters, neither of them work.
                tekkydaveundefined deckingmanundefined A Former User? 3 Replies Last reply Reply Quote 0
                  tekkydave @chas2706
                  @chas2706 have you tried adding the '^' to the P parameter. You have it configured for a High->Low transition but if it is not already set High by the pullup the Board wont see it.
                  ~ tekkydave ~
                  • chas2706undefined
                    chas2706
                    @tekkydave
                    Ok thanks. I will try that later. I'm printing at the minute.
                    Cheers.
                      @chas2706 I use this M581 P"!0.io3.in" T2 C0 which is pretty much the same as you. I also have a file called trigger2.g in the .sys folder. The reason I asked which pins you use are so that I could compare your configuration with my known working one. Mine is connected between io3in and gnd so I ask again, "which pins are you using"??
                      • chas2706undefined
                        chas2706
                        @deckingman
                        It is wired the same as your only on io2in. Connection is between io2in and gnd.
                        • chas2706undefined
                          chas2706
                          Like I said above, if I change M581 code in config.g to M574 P"!io2.in" , the switch acts as an end stop and works as such and so proves the wiring is correct.
                          • A Former User?
                            its not what you wrote so there we ask to confirm..
                            • chas2706undefined
                              chas2706
                              @bearer
                              Snippet from M581 Gcode documentation...…..
                              Any trigger number # greater then 1 causes the macro file sys/trigger#.g to be executed.
                              …….That is what I have done.
                              In my sys folder where config.g etc resides I have placed the trigger2.g file as per documentation.
                              • chas2706undefined
                                chas2706
                                @bearer
                                Sorry, there was a typo error in the first post. It should have said:
                                The file trigger2.g in the sys/ folder has the following code...…..
                                • chas2706undefined
                                  chas2706
                                  @tekkydave
                                  If I put M581 ^P"!io2.in"T2 C0 in config.g as you suggested I get the following error:
                                  Error: M581: Missing port name string when config.g reloads.
                                  • A Former User?
                                    A Former User
                                    ^ goes inside the ""
                                    is it safe to try and execute the trigger macro to see if there are any issues with the code?
                                    M98 P"/sys/trigger2.g" should to the trick to see if its okay
                                    ... or just post the config.g and trigger2.g contents so people can see whats going on.
                                    • chas2706undefined
                                      chas2706
                                      @bearer
                                      Running M98 P"trigger2.g"in the console works.
                                      adding ^ inside "" does not.
                                      Here is my config.g:
                                      ; generated by RepRapFirmware Configuration Tool v2.1.1 on Mon Nov 04 2019 16:21:57 GMT+0000 (Greenwich Mean Time)
                                      M555 P2 ; Set Marlin-style output
                                      G21 ; Set dimensions to millimetres
                                      M550 P"Duet3" ; set printer name
                                      M586 P0 S1 ; Enable HTTP
                                      M586 P1 S1 ; Enable FTP
                                      M586 P2 S1 ; Enable Telnet
                                      M669 K1 ; select CoreXY mode
                                      M569 P0 S1 ; X physical drive 0.0 goes forwards
                                      M569 P1 S1 ; Y physical drive 0.1 goes forwards
                                      M569 P2 S0 ; Z0 physical drive 0.2 goes forwards
                                      M569 P3 S0 ; Z1 physical drive 0.3 goes forwards
                                      M569 P4 S0 ; E0 physical drive 0.4 goes forwards
                                      ; Set drive mapping
                                      M584 X0 Y1 Z2:3 E4 ; Dual Z make sure drive 2 is left hand Z and 3 is right hand
                                      M92 X80.00 Y80.00 Z400.00 E96.00 ; set steps per mm
                                      M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min) - Jerk
                                      M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
                                      M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2) (print moves)
                                      M906 X1000 Y1000 Z1000 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      ; Leadscrew positions: The measurement is taken from X=0, Y=0. Therefore X will be negative, Y positive and middle of bed = 160
                                      M671 X-100:415 Y160:160 S2.0
                                      M208 X-15 Y-12 Z0 S1 ; Set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
                                      M208 X310 Y310 Z380 S0 ; set axis maxima
                                      M574 X1 S1 P"!io0.in" ; configure active-low endstop for low end on X via pin io0.in
                                      M574 Y1 S1 P"!io1.in" ; configure active-low endstop for low end on Y via pin io1.in
                                      M581 P"!io2.in" T2 C0 ; configure active-low endstop to run a macro called trigger2.g
                                      ; created in sys/ and let it trigger at any time without restrictions
                                      M558 P1 C"io3.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                      ; G31: the P is the reported Z value when triggered. X,Y are offset coordinates. Z is trigger height, you can decrease value if nozzle is too close
                                      ; or increase if too far away.
                                      G31 P500 X-30 Y-5 Z2.18 ; set Z probe trigger value, offset and trigger height
                                      ; Mesh Grid
                                      ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
                                      ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
                                      M557 X10:280 Y20:280 S50 ; Define small mesh grid
                                      ;M557 X10:280 Y10:280 S20 ; Define large mesh grid
                                      ; Heaters/temperature sensors
                                      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                                      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                                      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                                      M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                                      M307 H1 A299.8 C109.4 D4.0 S1.00 V12.3 B0 ; Autotune result for hotend
                                      M307 H0 A109.8 C457.8 D2.1 S1.00 V12.3 B0 ; Autotune result for bed
                                      ;CPU Temperature Calibration
                                      M912 P0 S-10.0
                                      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency (parts fan)
                                      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency (ext fan)
                                      ;Re-assigned fan pins
                                      ;CPU fan
                                      M950 F2 C"out9" ; create fan 2 (CPU fan)
                                      M308 S3 Y"mcutemp" A"mcutemp" ; set up a virtual sensor for cpu fan
                                      M106 P2 T45 H3 ; set fan 2 value. Fan comes on when cpu temp is above 45 degrees
                                      ;Led Lighting
                                      M950 F3 C"out4" Q500 ; create a fan 3 output to use for led lighting control on pin out4
                                      M106 P3 S0 ; set output default to off
                                      M563 P0 S"Extruder0" D0 H1 F0 ; define tool 0
                                      ; Custom settings
                                      ;M912 P0 S-15.8 ; Find correct value
                                      ;M42 P2 S255 ; Turn led lighting on full
                                      ;M98 P"LevelLeadscrews.g" ; Option to perform leadscrew levelling
                                      ;M98 PEnable Mesh Levelling ; Option to enable on start up
                                      T0 ; select first tool
                                      and my trigger2.g:
                                      ;trigger2.g
                                      ; Macro to safeguard machine upon failure of Z probing
                                      ;M291 P"Upper limit has been triggered!" R"Probe Failure!" S2
                                      • chas2706undefined
                                        chas2706
                                        Ok here's what ive found:
                                        In the M581 command I re-introduced the missing space between the "io2.in" and T2.
                                        I operated the microswitch connected to io2.in and nothing happened.
                                        I started a print and operated the microswitch and the trigger2.g executed.
                                        It seems that the "C0" parameter to set the code to execute at anytime does not work and only operates when printing.
                                        Or am I missing something?
                                        • chas2706undefined
                                          chas2706
                                          In the Gcode description for M581 it says:
                                          M581 - RepRapFirmware 3
                                          Parameters
                                          P Specify one or more pin names
                                          Tnn Logical trigger number to associate the endstop input(s) with, from zero up to a firmware-specific maximum
                                          C Condition: whether to trigger at any time (C0, default) or only when printing a file from SD card (C1)
                                          The Condition for C indicates that when set to C0 will trigger at any time. This is not entirely true. It will trigger AFTER all current moves have finished.
                                          So it is useless for my purpose.
                                          • A Former User?
                                            i belive that could be a bug as it did behave like described in the documentation a while ago.
                                            which versio are you using? M115will show it.
